Hi all,
How should I implementing SPMV in bsr format using CuSparse? I tried using related format api like cusparseCreateConstBsr
and compute api cusparseSpMV
, but occured an error : ** On entry to cusparseSpMV_bufferSize(): sparse matrix format BSR is not supported
. What’s the right way to do this computation?
Is there any demo code I can refer to?
Thank you
The documentation for cusparseSpMV
indicates:
The sparse matrix formats currently supported are listed below:
CUSPARSE_FORMAT_COO
CUSPARSE_FORMAT_CSR
CUSPARSE_FORMAT_CSC
CUSPARSE_FORMAT_SLICED_ELL
BSR is not one of those.
Some possibilities:
- switch your storage format to one of the supported ones for this op
- convert your BSR matrix to one of the supported types for this op
- use
cusparse<t>bsrmv()
The CUDA library sample codes are here but I don’t know that any pertain to BSR usage. However I think a csrmv example should be pretty close to bsrmv, such as this one. This portion of the documentation may also be of interest.
