hi everyone, I want to extract information from metadata in pipeline and display the data on customized pyqt UI. I don’t know how to access the metadata in the UI thread. Could anyone give me a hand?? Thanks a lot
Wheere are you running the pipeline from? What kind of metadata do you need??
Assuming you’re talking about nvinfer
: You can always attach a probe to an element’s pad after the nvinfer
element and extract it there. A reference can be found here: buffer probe attachment and callback example
I’m not sure this is the solution, but in the past, what I’ve done is :
- Inside the mentioned callback (which runs in this loop , append elements to a queue.Queue
- from the UI thread, read elements from the queue (eg using
Queue.get
Thank you so much, I‘ll try the way you mentioned.
