hello,Currently my nano is jetpack4.3 and deepstream4.0.2 version,But I want to use the latest nvdsanalytics plugin released by deepstream5.0 on nano。How can I use it without upgrading the jetpack and deepstream versions?
Below is the test I made myself:
1. I put the code package of deepstream5.0 on the nano,and then put deepstream-5.0 / lib / libnvds_dsanalytics.so under /opt/nvidia/deepstream/deepstream-4.0/lib/,put deepstream-5.0 / lib / gst-plugins / libnvdsgst-dsanalytics.so under /opt/nvidia/deepstream/deepstream-4.0/lib/gst-plugins,then execute ‘ ldconfig ’ command;
2.Execute ‘make’ command under deepstream5.0 / sources / app / sample_apps / deepstream-nvdsanalytics-test,can successfully compile the executable program of ‘deepstream-nvdsanalytics-test’.
3.Run the command ‘./deepstream-nvdsanalytics-test file: //xxx/sample_720p.mp4’ , and the following error will be reported:
One element could not be created. Exiting.
I located it a bit because the function 'nvdsanalytics = gst_element_factory_make (“nvdsanalytics”, “nvdsanalytics”); ’ failed to create this plugin and returned NULL.
The above is the process I performed, I hope you can help me, thank you very much!!
