Hi there,
I have a question on how to use the exact continuity in 2D cases.
My error message:
Error executing job with overrides: []
File "cylinder_2d.py", line 191, in run
slv.solve()
File "/usr/local/lib/python3.8/dist-packages/modulus-22.9-py3.8.egg/modulus/solver/solver.py", line 159, in solve
self._train_loop(sigterm_handler)
File "/usr/local/lib/python3.8/dist-packages/modulus-22.9-py3.8.egg/modulus/trainer.py", line 521, in _train_loop
loss, losses = self._cuda_graph_training_step(step)
File "/usr/local/lib/python3.8/dist-packages/modulus-22.9-py3.8.egg/modulus/trainer.py", line 702, in _cuda_graph_training_step
self.loss_static, self.losses_static = self.compute_gradients(
File "/usr/local/lib/python3.8/dist-packages/modulus-22.9-py3.8.egg/modulus/trainer.py", line 54, in adam_compute_gradients
losses_minibatch = self.compute_losses(step)
File "/usr/local/lib/python3.8/dist-packages/modulus-22.9-py3.8.egg/modulus/solver/solver.py", line 52, in compute_losses
return self.domain.compute_losses(step)
File "/usr/local/lib/python3.8/dist-packages/modulus-22.9-py3.8.egg/modulus/domain/domain.py", line 133, in compute_losses
constraint.forward()
File "/usr/local/lib/python3.8/dist-packages/modulus-22.9-py3.8.egg/modulus/domain/constraint/continuous.py", line 116, in forward
self._output_vars = self.model(self._input_vars)
File "/usr/local/lib/python3.8/dist-packages/torch/nn/modules/module.py", line 1194, in _call_impl
return forward_call(*input, **kwargs)
File "/usr/local/lib/python3.8/dist-packages/modulus-22.9-py3.8.egg/modulus/graph.py", line 220, in forward
outvar.update(e(outvar))
File "/usr/local/lib/python3.8/dist-packages/modulus-22.9-py3.8.egg/modulus/eq/derivatives.py", line 84, in forward
grad_var = self.prepare_input(input_var, grad_sizes.keys())
File "/usr/local/lib/python3.8/dist-packages/modulus-22.9-py3.8.egg/modulus/eq/derivatives.py", line 72, in prepare_input
return [input_variables[x] for x in mask]
File "/usr/local/lib/python3.8/dist-packages/modulus-22.9-py3.8.egg/modulus/eq/derivatives.py", line 72, in <listcomp>
KeyError: 'z'
My code:
How do I use the function “curl” in this 2D case?
Many thanks in advance.
