I’m a bit stuck on using hostnm to print the hostname. This is my program:
program main
implicit none
character(20) :: name
integer :: status
call HostNm(name, status)
print*, "status = ", status
print*, "name = ", name
end program main
The problem is that when I compile this with pgf90, sometimes I get a load of gibberish at the end of the hostname because the character length is too long:
status = 32767
name = larchkC’Z
and at other times I just get a segmentation fault.
If I compile with gfortran I get this:
status = 0
name = larch
Which shows no error. What’s the correct way to use hostnm?
Hi Tom,
HostNM is a non-standard extension and the version we use is slightly different then the one GNU uses. Ours is in the form:
integer function hostnm(nm)
character*(*) nm
Full details can be found in the PGI Fortran Reference Guide
So a slight change in your program will get it to work correctly:
palomar02:/tmp% cat hostnm.F90
program main
implicit none
integer :: status
#ifdef __PGI
integer :: HostNm
status = HostNm(name)
#else
call HostNm(name,status)
#endif
end program main
palomar02:/tmp% pgfortran -Mpreprocess hostnm.F90; a.out
status = 0
name = palomar02
Hope this helps,
Mat
