Hi
I want to read manufacture information of UCD90160 by i2c.
But I find that I can’t do it because smbus block read can’t be used (I use i2c-tools).
How can I read manufacture information from UCD90160 by tx1 ?
Hi
i2cdump with sudo permission should help.
Could you elaborate why smbus cannot use?
Hello Wayne
I tried to use below command to read data
root@tegra-ubuntu:/home/ubuntu# i2cdump -f -y 7 0x6b s 0x9a
But I got error message as below
Error: Adapter does not have SMBus block read capability
Then I find that the i2c doesn’t support smbus block read.
root@tegra-ubuntu:/home/ubuntu# i2cdetect -F 7
Functionalities implemented by /dev/i2c-7:
I2C yes
SMBus Quick Command yes
SMBus Send Byte yes
SMBus Receive Byte yes
SMBus Write Byte yes
SMBus Read Byte yes
SMBus Write Word yes
SMBus Read Word yes
SMBus Process Call yes
SMBus Block Write yes
SMBus Block Read no
SMBus Block Process Call no
SMBus PEC yes
I2C Block Write yes
I2C Block Read yes
