1, LI-JXAV-MIPI-ADPT 4CAM V1.0;
2, 3 leopard imx274 cameras;
3, R32.1, /dev/video0, video1, video2, video3 exist;
4, opencv3.3.1 is removed and opencv3.4.0 is installed;
5, cmd: “gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! ‘video/x-raw(memory:NVMM), width=(int)1920,height=(int)1080’ ! nvvidconv flip-method=0 ! ‘video/x-raw, format=(string)I420’ ! xvimagesink -e” works fine;
6, sample codes can be run, but video is not fluent:
#include <stdio.h>
#include <opencv2/opencv.hpp>
using namespace cv;
using namespace std;
int main(int argc, char** argv)
VideoCapture cap("nvarguscamerasrc sensor-id=0 ! video/x-raw(memory:NVMM), width=1280, height=720,format=NV12, framerate=30/1 ! nvvidconv ! video/x-raw,format=I420 ! appsink");
if (!cap.isOpened())
cout << "Failed to open camera." << endl;
return -1;
for(;;)
Mat frame;
cap >> frame;
Mat bgr;
cvtColor(frame, bgr, CV_YUV2BGR_I420);
imshow("original", bgr);
waitKey(1);
cap.release();
7, cmd: “v4l2-ctl --set-fmt-video=width=1920,height=1080,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=3 --stream-to=IMX274.raw -d /dev/video0” can be run, and just see result “<<<”, dmesg is attached;
The output video is bad quality, so I change “format=I420” according to Accelerated_GStreamer_User_Guide.pdf, for example, update to “format=BGRA”, then report:
nvidia@nvidia-desktop:~/Downloads$ ./simple_opencv
VIDEOIO ERROR: V4L: device nvarguscamerasrc sensor-id=1 ! video/x-raw(memory:NVMM), width=1280, height=720,format=NV12, framerate=30/1 ! nvvidconv ! video/x-raw,format=BGRA ! appsink: Unable to query number of channels
(Argus) Error Timeout: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function openSocketConnection(), line 215)
(Argus) Error Timeout: Cannot create camera provider (in src/rpc/socket/client/SocketClientDispatch.cpp, function createCameraProvider(), line 102)
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:515 Failed to create CameraProvider
I try to adapt codes of “argus_camera” into opencv’s capture because the output video is perfect after “argus_camera --device=0”, but it’s a big task. I also refer to Installing on Linux, but it makes me feel dizzy. Would experts help me? Thanks in advanced.
dmesg.txt (81.6 KB)
