How to use jetson orin nx endpoint
Currently, I use jetson orin nx and custom board. I want to use endpoint in jetson orin nx.
I understand that in jetson linux 36.4, endpoint is defined as 14160000
but in executing command line,
# cd /sys/kernel/config/pci_ep/
# mkdir functions/pci_epf_tvnet/func1
# echo 16 > functions/pci_epf_tvnet/func1/msi_interrupts
# ln -s functions/pci_epf_tvnet/func1 controllers/141a0000.pcie_ep/
# echo 1 > controllers/141a0000.pcie_ep/start
endpoint is being used as 141a0000
is it correct?
Not correct. You should use 14160000.
