I would like to allocate 2MB of DMA buffer using dma_alloc_coherent. I originally intended to use pci_alloc_consistent, but this API fails when trying to allocate a 2MB buffer.
JetPack and kernel versions are as follows:
JetPack version
JetPack 4.2.1. -
Kernel
Linux tegra-ubuntu 4.9.140-tegra #1 SMP PREEMPT Tue Jul 16 17:09:53 PDT 2019 aarch64 aarch64 aarch64 GNU/Linux
The source code and Print output are listed below:
#define PRINTF(…) printk(VA_ARGS)
typedef struct {
caddr_t pDmaBuf;
dma_addr_t pDmaAdr;
ULONG bDmaSize;
} BoardDEV;
static int32_t attach_dmamem(BoardDEV *dev)
ULONG length;
char *szMethod;
PRINTF("%s() Entry\n",__func__);
if(dev!=NULL)
for(length=DMA_BUFFER_LENGTH;length>0x100;length/=2)
szMethod="dma_alloc_coherent";
dev->pDmaBuf=dma_alloc_coherent(NULL,length,&dev->pDmaAdr,GFP_KERNEL|GFP_DMA);
if(dev->pDmaBuf!=NULL)
dev->bDmaSize=length;
PRINTF("%s() %s(%08lx) Success\n",__func__,szMethod,dev->bDmaSize);
PRINTF(" size=0x%lxbytes\n",dev->bDmaSize); /* size=0x80000bytes */
PRINTF(" cpuaddr=0x%p\n",dev->pDmaBuf); /* cpuaddr=0xffffff800b081000 */
PRINTF(" devaddr=0x%p\n",(void*)dev->pDmaAdr); /* devaddr=0x00000000fff00000 */
PRINTF(" (busaddr=0x%p)\n",(void*)virt_to_phys(dev->pDmaBuf)); /* busaddr=0x0000000083281000 */
PRINTF("%s() exit\n",__func__);
return(0);
else
PRINTF("%s() alloc (%08lx) Failure\n",__func__,length);
dev->pDmaBuf=NULL;
dev->bDmaSize=0;
return(-EINVAL);
int drv_probe(struct pci_dev *devp,const struct pci_device_id *entp)
attach_dmamem(dev);
static int doDmaTrans(BoardDEV *dev,DWORD dmaOffset,ULONG ddrOffset,int length,int pci2local)
DWORD mask[2];
ULONG dmaAddr;
DWORD read_addressL;
DWORD write_addressL;
DWORD read_addressH;
DWORD write_addressH;
if((dmaAddr=dev->pDmaAdr)!=0)
PRINTF("%s(dma:+%08x,ddr:+%08lx) Entry. dmaAddr:0x%08lx\n",__func__,dmaOffset,ddrOffset,dmaAddr);
fpgaWL(dev,0x1000,0xfffffffc); // 0x1000 is the offset for translation register
fpgaWL(dev,0x1004,0xffffffff);
// reading out the resulted mask of path through
mask[0]=fpgaRL(dev,0x1000); /* Low 32Bit (ff000000) */
mask[1]=fpgaRL(dev,0x1004); /* High 32Bit (ffffffff) */
PRINTF("%s() mask[0]:0x%08x, mask[1]:0x%08x\n",__func__,mask[0],mask[1]);
// program address translation table
dmaAddr+=dmaOffset;
fpgaWL(dev,0x1000,(DWORD)(dmaAddr&mask[0])|1); /* setting lower address */
fpgaWL(dev,0x1004,(DWORD)((dmaAddr>>32)&mask[1])); /* setting upper address */
PRINTF("%s() fpgaWL(0x1000,0x%08x)\n",__func__,(DWORD)(dmaAddr&mask[0])|1);
PRINTF("%s() fpgaWL(0x1004,0x%08x)\n",__func__,(DWORD)((dmaAddr>>32)&mask[1]));
if(pci2local)
// generate buffer base addresses and lengths
read_addressL = (DWORD)dmaAddr&~mask[0];
read_addressH = (DWORD)(PCIADRMAP>>32); /* PCIADRMAP:0x3_0000_0000 */
else
read_addressL = (DWORD)ddrOffset; //ddrOffset is the SOPC address for DDR/OCM
read_addressH = (DWORD)(ddrOffset>>32); //ddrOffset is the SOPC address for DDR/OCM
fpgaWL(dev,MSGDMADESC+0x00,read_addressL);
PRINTF("%s() fpgaWL(0x%08x,0x%08x)\n",__func__,MSGDMADESC+0x00,read_addressL);
fpgaWL(dev,MSGDMADESC+0x04,write_addressL);
PRINTF("%s() fpgaWL(0x%08x,0x%08x)\n",__func__,MSGDMADESC+0x04,write_addressL);
fpgaWL(dev,MSGDMADESC+0x14,read_addressH);
PRINTF("%s() fpgaWL(0x%08x,0x%08x)\n",__func__,MSGDMADESC+0x14,read_addressH);
fpgaWL(dev,MSGDMADESC+0x18,write_addressH);
PRINTF("%s() fpgaWL(0x%08x,0x%08x)\n",__func__,MSGDMADESC+0x18,write_addressH);
Print Log:
10 0:00:00.014437(+0.000003) 5:doDmaTrans(dma:+00000000,ddr:+00100000) Entry. dmaAddr:0xe0100000
11 0:00:00.014444(+0.000007) 5:doDmaTrans() mask[0]:0xff000000, mask[1]:0xffffffff
12 0:00:00.014445(+0.000001) 5:doDmaTrans() fpgaWL(0x1000,0xe0000001)
13 0:00:00.014446(+0.000001) 5:doDmaTrans() fpgaWL(0x1004,0x00000000)
14 0:00:00.014450(+0.000004) 5:doDmaTrans() fpgaWL(0x00018000,0x00100000)
15 0:00:00.014451(+0.000001) 5:doDmaTrans() fpgaWL(0x00018004,0x00100000)
16 0:00:00.014453(+0.000002) 5:doDmaTrans() fpgaWL(0x00018014,0x00000000)
17 0:00:00.014454(+0.000001) 5:doDmaTrans() fpgaWL(0x00018018,0x00000003)
18 0:00:00.028845(+0.014391) 5:doDmaTrans(dma:+00100000,ddr:+00200000) Entry. dmaAddr:0xe0100000
19 0:00:00.028853(+0.000008) 5:doDmaTrans() mask[0]:0xff000000, mask[1]:0xffffffff
20 0:00:00.028854(+0.000001) 5:doDmaTrans() fpgaWL(0x1000,0xe0000001)
21 0:00:00.028854(+0.000000) 5:doDmaTrans() fpgaWL(0x1004,0x00000000)
22 0:00:00.028858(+0.000004) 5:doDmaTrans() fpgaWL(0x00018000,0x00200000)
23 0:00:00.028859(+0.000001) 5:doDmaTrans() fpgaWL(0x00018004,0x00200000)
24 0:00:00.028860(+0.000001) 5:doDmaTrans() fpgaWL(0x00018014,0x00000000)
25 0:00:00.028861(+0.000001) 5:doDmaTrans() fpgaWL(0x00018018,0x00000003)
Although the 2MB buffer can now be allocated using dma_alloc_coherent. However the comparison does not match and the following error occurs in the system message when DMA is actually operated,
Am I using dma_alloc_coherent incorrectly? I would appreciate any guidance on how to resolve this error.
=Error log=
mc-err: (255) csr_afir: EMEM address decode error arm-smmu 12000000.iommu: Unhandled context fault: iova=0xe0200000, fsynr=0x2, cb=22, sid=17(0x11 - AFI), pgd=1671d4003, pud=1671d4003, pmd=0, pte=0 arm-smmu 12000000.iommu: Unhandled context fault: iova=0xe0203340, fsynr=0x2, cb=22, sid=17(0x11 - AFI), pgd=1671d4003, pud=1671d4003, pmd=0, pte=0 arm-smmu 12000000.iommu: Unhandled context fault: iova=0xe0206f40, fsynr=0x2, cb=22, sid=17(0x11 - AFI), pgd=1671d4003, pud=1671d4003, pmd=0, pte=0 arm-smmu 12000000.iommu: Unhandled context fault: iova=0xe020a000, fsynr=0x2, cb=22, sid=17(0x11 - AFI), pgd=1671d4003, pud=1671d4003, pmd=0, pte=0 arm-smmu 12000000.iommu: Unhandled context fault: iova=0xe020d480, fsynr=0x2, cb=22, sid=17(0x11 - AFI), pgd=1671d4003, pud=1671d4003, pmd=0, pte=0 arm-smmu 12000000.iommu: Unhandled context fault: iova=0xe0210500, fsynr=0x2, cb=22, sid=17(0x11 - AFI), pgd=1671d4003, pud=1671d4003, pmd=0, pte=0 arm-smmu 12000000.iommu: Unhandled context fault: iova=0xe0213180, fsynr=0x2, cb=22, sid=17(0x11 - AFI), pgd=1671d4003, pud=1671d4003, pmd=0, pte=0 arm-smmu 12000000.iommu: Unhandled context fault: iova=0xe0216980, fsynr=0x2, cb=22, sid=17(0x11 - AFI), pgd=1671d4003, pud=1671d4003, pmd=0, pte=0 arm-smmu 12000000.iommu: Unhandled context fault: iova=0xe0219300, fsynr=0x2, cb=22, sid=17(0x11 - AFI), pgd=1671d4003, pud=1671d4003, pmd=0, pte=0
Best Regards,
UNA
