hy_401
November 24, 2021, 3:26pm
1
Dear sir:
The m.2 disk is detected successfully. The result of lsblk is as following:
root@tegra-ubuntu:/etc# lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
loop0 7:0 0 16M 1 loop
mtdblock0 31:0 0 32M 0 disk
mmcblk0 179:0 0 14.7G 0 disk
├─mmcblk0p1 179:1 0 14G 0 part /
├─mmcblk0p2 179:2 0 64M 0 part
├─mmcblk0p3 179:3 0 64M 0 part
├─mmcblk0p4 179:4 0 448K 0 part
├─mmcblk0p5 179:5 0 448K 0 part
├─mmcblk0p6 179:6 0 63M 0 part
├─mmcblk0p7 179:7 0 512K 0 part
├─mmcblk0p8 179:8 0 256K 0 part
├─mmcblk0p9 179:9 0 256K 0 part
├─mmcblk0p10 179:10 0 300M 0 part
└─mmcblk0p11 179:11 0 199.1M 0 part
mmcblk0boot0 179:32 0 4M 1 disk
mmcblk0boot1 179:64 0 4M 1 disk
mmcblk0rpmb 179:96 0 4M 0 disk
zram0 252:0 0 971.5M 0 disk [SWAP]
zram1 252:1 0 971.5M 0 disk [SWAP]
zram2 252:2 0 971.5M 0 disk [SWAP]
zram3 252:3 0 971.5M 0 disk [SWAP]
nvme0n1 259:0 0 119.2G 0 disk
How to mount the disk by modify the fstab?
This question sounds not related to jetson itself.
So let me put an online search result to you.
Adding a new hard drive or solid-state drive to your Linux computer? You’ll need to edit your fstab file. A lot of people find the very idea scary. Yes, it’s critical that you get it right, but armed with the right knowledge, it really isn’t...
Est. Reading Time: 14 minutes
hy_401
November 27, 2021, 2:07pm
4
Sorry for late reply!
My actually intention is how bring up the nvme disk. My design is emmc disk is used for boot disk, the nvme disk is just used for data disk. How to bring up the nvme disk?
https://elinux.org/Jetson/L4T/Boot_From_External_Device
Actually, you just need to give “root=your_nvme disk_drive_path” to the kernel cmdline.
hy_401
November 30, 2021, 12:50am
6
Tks!
I have read the topic. It is used for booting from nvme. But i just used nvme for data disk.
MtHiker
November 30, 2021, 2:39am
8
I tested this on the Jetson AGX Xavier developer kit, and Samsung Evo 970 Plus NVMe.
# make sure if /dev/nvme0n1 exists
$ sudo parted /dev/nvme0n1
(parted) mklabel gpt
Yes/No? yes
(parted) mkpart primary ext4 0 100%
Ignore/Cancel? Ignore
(parted) quit
$ sudo mkfs.ext4 -j /dev/nvme0n1p1
Proceed anyway? (y,N)
$ sudo mkdir -p /mnt
$ sudo mount /dev/nvme0n1p1 /mnt
jax@jax-desktop:~$ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/mmcblk0p1 28G 17G 10G 62% /
none 7.7G 0 7.7G 0% /dev
tmpfs 7.7G 404K 7.7G 1% /dev/shm
tmpfs 7.7G 46M 7.7G 1% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 7.7G 0 7.7G 0% /sys/fs/cgroup
tmpfs 1.6G 144K 1.6G 1% /run/user/1000
/dev/nvme0n1p1 458G 73M 435G 1% /mnt
to modify /etc/fstab, you may find a blkid as follow:
$ blkid /dev/nvme0n1p1 -s UUID -o value
G’luck and leave a note for any mistakes what I did.
hy_401
November 30, 2021, 3:03am
9
Tks!
Dear MtHiker and WayneWWW, if i want to do these operations in bash script at booting up, how to do?
Especially, the mount operation can be modified in fstab. But the part and format operation is done only one time, how to do?
MtHiker
November 30, 2021, 8:25am
10
parted
command needs to be run just one time for a device.
And if you add a list in a /etc/fstab
, the point will be mounted automatically at boot up time.
How about make and run a simple script to init it?
hy_401
November 30, 2021, 11:37am
11
parted
command needs to be run just one time for a device.------- Can this executed automatically by script?
