As indicated here (http://docs.nvidia.com/cuda/inline-ptx-assembly/index.html#axzz47nNiNXji),
you can stop memory optimization adding the “memory”.
asm volatile (“add.f32 %0, %1, %2;” : “=f”(k) : “f”(i),“f”(j) :: “memory”);
But when compile the kernel, it reports the following.
error: expected a “)”
Any suggestions?
:: “memory”
should be
: “memory”
manual example
asm volatile ("mov.u32 %0, %%clock;" : "=r"(x) :: "memory")
employs “::” because it has no the “constraint”(input) part in the same way as here:
If there is no output operand, the colon separators are adjacent, e.g.:
asm("mov.s32 r1, %0;" :: "r"(i));
it also said right there:
you can add a "memory" clobbers specification after a <b><u>3rd colon</u></b>
