Hi and good time
Hope you are feeling well
I wana use nvivafilter and nvsample for a processing application
In the sample you have wrote a funcation named
static void add_metadata(void ** usrptr)
And in the iva_metadata.h file is defined some metadata varible
typedef struct _location_t Location;
struct _location_t
int x1, y1;
int x2, y2;
typedef struct _bbox_t BBOX;
struct _bbox_t {
unsigned int framecnt;
unsigned int objectcnt;
Location location_list[NUM_LOCATIONS];
Right now,i wanna know how i can use the metadata in the gstreamer Main looper
For example ,how can i get the metadata in main gsteramer loop launcher??
May you help me??
Thank you for your time
Appreciate that
Best regards.
