How to use multiple USB camera with Jetson AGX Orin dev kit?
Hello, I have a Jetson AGX orin and trying to connect 3x 4k USB cameras. However, when I launch with ros2 v4l2 node, it shows the following errors.
Failed stream start: No space left on device (28)
I saw some topics says that need to patch or buy the carrier board. But I want to try with dev kit, what is the proper way to make the Jetson AGX orin to support more than 2 cameras?
There are two type-C ports on the developer kit. Please use type C to A adapters to connect to the cameras. To use bandwidth of the two type-C ports.
