How to use NvBufSurfTransformSetSessionParams in dps 6.1
GPU
• DeepStream Version
6.1.1
• TensorRT Version
TrT 8
11.7
questions
use the smilar codes
I want to dump images in deepstream, before dps 6.1.1, It worked very well with the following code, but now in dps 6.1.1, this program throws no error and create no boxes in yolov5. if I comment the last line, the boxes were created correctly.
NvBufSurface *dst_surface = NULL;
NvBufSurface surface_idx;
surface_idx = *surface;
surface_idx.surfaceList = &(surface->surfaceList[batch_id]);
surface_idx.numFilled = surface_idx.batchSize = 1;
int batch_size = surface_idx.batchSize;
cudaStream_t cuda_stream;
cudaError_t cuda_err=cudaStreamCreate (&cuda_stream);
//resize to origin dimension, need to recalculate the bbox later
NvBufSurfTransformRect src_rect, dst_rect;
src_rect.top   = 0;
src_rect.left  = 0;
dst_rect.top   = 0;
dst_rect.left  = 0;
src_rect.width = (guint) surface->surfaceList[batch_id].width;
src_rect.height= (guint) surface->surfaceList[batch_id].height;
dst_rect.width = frame_width;
dst_rect.height= frame_height;
NvBufSurfTransformParams nvbufsurface_params;
nvbufsurface_params.src_rect = &src_rect;
nvbufsurface_params.dst_rect = &dst_rect;
nvbufsurface_params.transform_flag =  NVBUFSURF_TRANSFORM_CROP_SRC | NVBUFSURF_TRANSFORM_CROP_DST;
nvbufsurface_params.transform_filter = NvBufSurfTransformInter_Default;
NvBufSurfaceCreateParams nvbufsurface_create_params;
nvbufsurface_create_params.gpuId  = surface->gpuId;
nvbufsurface_create_params.width  = frame_width;
nvbufsurface_create_params.height = frame_height;
nvbufsurface_create_params.size = 0;
nvbufsurface_create_params.colorFormat = NVBUF_COLOR_FORMAT_RGBA;
nvbufsurface_create_params.layout = NVBUF_LAYOUT_PITCH;
#ifdef aarch64
nvbufsurface_create_params.memType = NVBUF_MEM_DEFAULT;
#else
nvbufsurface_create_params.memType = NVBUF_MEM_CUDA_UNIFIED;
#endif
cuda_err = cudaSetDevice (surface->gpuId);
int create_result = NvBufSurfaceCreate(&dst_surface,batch_size,&nvbufsurface_create_params);
NvBufSurfTransformConfigParams transform_config_params;
NvBufSurfTransform_Error err;
transform_config_params.compute_mode = NvBufSurfTransformCompute_Default;
transform_config_params.gpu_id = surface->gpuId;
transform_config_params.cuda_stream = cuda_stream;
err = NvBufSurfTransformSetSessionParams (&transform_config_params);
Did you use docker or run directly on you dgpu device?
You mean to comment the err = NvBufSurfTransformSetSessionParams(&transform_config_params);, the box create correctly?
Could you provide us the minimized code that can run well?
@yuweiw Thanks for your reply. I used Docker. 6.1.1-devel.
Yes, if i commented this line and below, it worked smoothly, and showed the correct boxes in my log , the same as the previous deepstream version.
It would be somehow difficult for me to make this minimized runable code because of my limited skill and our complicated project.
Is there any alternative way to realize how to dump an image?
@yuweiw
you can refer to this link: RTSP camera access frame issue - #25 by neophyte1
I also used this
Even when I just put this in my code, and nowhere would access to it, there are no boxes in my log, and commented, a lot of boxes come out in log.
I followd this repo and print boxes there. GitHub - marcoslucianops/DeepStream-Yolo: NVIDIA DeepStream SDK 6.1.1 / 6.1 / 6.0.1 / 6.0 configuration for YOLO models
If you are using dGPU, you can just get the raw databuffer from the nvbufersurface. Like:
  uint8_t* src_data = (uint8_t*) malloc(ip_surf->surfaceList[0].dataSize);
  if(src_data == NULL) {
    GST_ERROR("Error: failed to malloc src_data \n");
  cudaMemcpy((void*)src_data,
              (void*)ip_surf->surfaceList[0].dataPtr,
              ip_surf->surfaceList[0].dataSize,
              cudaMemcpyDeviceToHost);
Just from your code, I can’t see where you get the image data. Could you just add your code in our open source demo, like gstdsexample.cpp? It’s similar to your case.
