Hi, I want to use the nvds_logger to get the debug information like decoder throughput and the ML throughput. Is it enable out-of-the-box in the deepstream3.0 docker container? or should i need to add it into the deepstream-app-main.c?
Can you let me know the steps to enable this in the code and make the project again and what is the command to get the debug info?
Would you mind to share your environment first?
This docker image only supports desktop environment and cannot be running on the Jetson.
(I ask this because this is a Jetson board)
nvds_logger is available for deepstream-3.0 on Jetson.
You can find some information in ${deepstream_sdk_on_jetson}/sources/libs/nvds_logger/README.
Hi, thanks for the reply.
I am actually running the deepstream3.0 container in cloud (not on Jetson Board). I posted this question here since i could not find a forum for deepstream on a non-jetson usecase.
Do you mean that nvds_logger does not work on cloud, no right? It should work, i guess.
Are there code hooks to be added to my deepstream3.0 container.
Hi, Also can you let me know the steps to replace the inference with yolov2. should i use the github page where the yolo-app is there?
will it work inside the container?
