How to use NvMediaxxxxInsertPreNvSciSyncFence?
Software Version
DRIVE OS 6.0.6
[*] DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] other
SDK Manager Version
1.9.3.10904
[*] other
Host Machine Version
[*] other
I encountered some problems when applying the method mentioned above, where I use the EOFfence of the previous operation as a preference feed for the next operation, specifically in the context of Nvmedia2D and NvMediaLDC:
  1. Do I need to reconcile the NvSciSyncAttrList with both Nvmedia2D and NvMediaLDC attributes when creating an NvsciSyncObj? I found that attempting this using NvSciSyncAttrListReconcile results in a failure.
  2. I created an NvsciSyncObj and registered it as an eofsyncobj for Nvmedia2D and as a presyncobj for NvMediaLDC. Then, I used NvMediaLdcInsertPreNvSciSyncFence to feed the EOFfence of Nvmedia2D’s operation to NvMediaLDC. However, I noticed that in practice, NvMediaLDC doesn’t wait for Nvmedia2D’s operation to finish, as the call to NvMedia2DUnregisterNvSciBufObj after waiting for NvMediaLDC to finish still returns that it’s in use.
Could you please provide me with some sample code to guide me on how to proceed or give me some advice? So far, I haven’t achieved the expected results.
Are you using P3710 Developer Kit?
Yes,it is.
We will investigate this issue with our team and provide you with further guidance.
Could you please provide more context regarding your usage of NvSciSyncAttrListReconcile()? Specifically, could you describe how you are calling the function and provide details about the error code you received when it resulted in a failure? Additional information will help us better understand and address the issue you’re facing.
Is this still an issue to support? Any further information can be shared? Thanks
