How to use nvosd to display the segmentation result?
**• Hardware Platform (Jetson / GPU)GPU
**• DeepStream Version6.0
So I noticed the nvsegvisual is used for segmentation result, but the result I want is a mask overlaid on the orignal image like using nvosd plugin.
I found the nvosd plugin could display instance segmentation result with bboxes. I wonder how to use nvosd to display the segmentation result? Do I have to manually set up the relevant bboxes, in order to convert the segmentation result to the instance segmentation result, and finally use the nvosd plugin.
In theory, it is possible. We will consider implementing segmentation display with nvosd in the future. Please pay attention to future updates.
