On TX2, by using GSTREAMER a pipeline is set up for video playback.
・Use “playbin” for playback pipeline.
・Encoder uses NVIDIA’s “omxh264enc”.
・“nvvidconv” will be used for the video format converter.
※Video input is uyvy format, but omxh264 does not accept uyvy format
Uyvy-> I420’s convert element is necessary.
here are the questions
(1) Is it possible to use “nvvidconv” in “playbin”?
(2) If possible, what’s the best way of doing it?
The current situation is as follows.
・Playbin is video
videoconvert" is automatically selected as the format conversion element.
・At first glance, playbinn doesn’t have element specific property for conversion
It looks like you would like to run a transcoding case. For transcoding, suggest you use decodebin or uridecodebin to link with omxh264enc(or nvv4l2h264enc).
I am sorry, I made a mistake in my previous post, actually I need to ask the following
On NVIDIA Jetson TX2, by using GSTREAMER a pipeline is set up for video playback.
・Use playbin for playback pipeline.
・Decoder uses NVIDIA “omxh264dec”.
※I want to have output Video in uyvy format, but encoded in I420 format .
Therefore, I420 → uyvy convert element is required.
(1) Is it possible to use “nvvidconv” in playbin?
・Playbin a “videoconvert” automatically selected as the video format conversion element.
・At first glance, playbinn doesn’t have element specific property for conversion.
playbin is supposed to be used in video playback. For format conversion, you may use uridecodebin. What is the next action of having UYVY buffers? Dump to files one by one?
I am sorry, I think, I could not make you understand my question.
My question is
playbin chooses videoconverter automatically, but how can I make playbin to select “nvvidconv” instead of “videoconvert” from multiple choices?
videoconverter is Software processing.
nvvidconvis HardWare processing.
