I am currently using jetson xavier with jetpack 5.0.1 and l4t-base:r34.1.1
I am using a dockerfile to run gstream pipeline. But i am not able to acess nvvidconv inside docker file.
kindly help,
Thank you
kindly help,
Thank you
Jetpack 5.0.1 is developer preview. Please upgrade to 5.0.2.
Or you may use Jetpack 4.6.2 which is a stable release for Xavier.
Okay… Do you happen to have any dockerfile which works with nvvidconv for gstream pipeline…?
I have upgraded jetpack to 5.0.2, when i run the gstream pipeline inside docker it gives below error,
packages/webrtc_operator_data_transfer/data_transfer_node.py", line 352, in loop
self.start_pipeline()
File “/root/ideliver_teleoperation/install/webrtc_operator_data_transfer/lib/python3.8/site-packages/webrtc_operator_data_transfer/data_transfer_node.py”, line 252, in start_pipeline
self.pipe = Gst.parse_launch(PIPELINE_DESC)
gi.repository.GLib.Error: gst_parse_error: no element “nvv4l2vp9enc” (1)
Hi, any help would be appreciated…
