deepstream_test_1_usb_2.py (15.2 KB)
this test app just run with one model, try with deepstream-test2
I know but I modified it just like test2
Primary detector and tracker works.
try add: process-mode=2 to sgie config
Adding process-mode=2 causes Segmentation fault on first detection
can you show the error
i think you need debug
parse-bbox-func-name=NvDsInferParseCustomTfSSD
custom-lib-path=/home/netcoz/CustomLibPath/libnvds_infercustomparser.so
follow you output
in sgie config i see: network-mode=1 but use parse-bbox-func-name=NvDsInferParseCustomTfSSD. must be parse-bbox-func-name=NvDsInferClassiferParseCustomSoftmax
Note: NvDsInferClassiferParseCustomSoftmax work for resnet so you need custom this function to work with onnx
nvdsinfer_customclassifierparser.cpp (4.3 KB)
Found this and added below lines it works now.
parse-bbox-func-name=NvDsInferParseCustomONNX
custom-lib-path=/opt/nvidia/deepstream/deepstream-5.1/sources/libs/nvdsinfer_customparser/libnvds_infercustomparser.so
Thank you @PhongNT for support
