Hi team,
I have been using opencv c API for a while since deepstream-app was written in c language. However opencv c API is not supported now and I need to use opencv c++ API instead. And I saw some posts about cropping frame and saving images used cv::imwrite() and etc., which are only supported in opencv c++ API. So would you please help advise how to use opencv c++ API in deepstream-app codes ASAP? Anything need to be modified in MakeFile? Thanks a lot!
I used gcc compiler and x11 to compile deepstream-app codes and app runs ok. If I changed from #include “oepncv/cv.h” to #include “opencv/cv.hpp”, it will prompt error as below:
/usr/local/include/opencv2/core.hpp:49:4: error: #error core.hpp header must be compiled as C++
• Hardware Platform (Jetson / GPU) GPU GeForce RTX 2080 Ti
• DeepStream Version 4.0.2
• JetPack Version (valid for Jetson only) N/A
• TensorRT Version 6.0.1.5
• NVIDIA GPU Driver Version (valid for GPU only) 435.21
