• Hardware Platform (Jetson / GPU) T4 dGPU
• DeepStream Version 6.3
• TensorRT Version
The plan is to use OpenCV’s CUDA method to process GPU data in the callback function(in osd prob), as shown below, but the output image of DeepStream has not changed. Please help see what the reason is.
GstPadProbeReturn post_process(GstPad *pad, GstPadProbeInfo *info,
gpointer u_data)
NvDsMetaList *l_frame = NULL;
GstBuffer *buf = (GstBuffer *)info->data;
GstMapInfo in_map_info;
NvBufSurface *surface = NULL;
NvDsMetaList *l_obj = NULL;
NvDsObjectMeta *obj_meta = NULL;
if (!gst_buffer_map(buf, &in_map_info, GST_MAP_READWRITE))
g_print("Error: Failed to map gst buffer\n");
gst_buffer_unmap(buf, &in_map_info);
return GST_PAD_PROBE_OK;
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta(buf);
surface = (NvBufSurface *)in_map_info.data;
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next)
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *)(l_frame->data);
int offset = 0;
fps_count++;
cv::cuda::GpuMat gpu_blur, gpu_frame;
gint frame_width = (gint)surface->surfaceList[frame_meta->batch_id].width;
gint frame_height = (gint)surface->surfaceList[frame_meta->batch_id].height;
gint frame_step = surface->surfaceList[frame_meta->batch_id].pitch;
void *frame_data = surface->surfaceList[frame_meta->batch_id].mappedAddr.addr[0];
gpu_frame = cv::cuda::GpuMat(frame_height, frame_width,
CV_8UC3, surface->surfaceList[frame_meta->batch_id].dataPtr, frame_step);
cv::cuda::resize(gpu_frame, gpu_frame, mosaicSize);
cv::cuda::resize(gpu_frame, gpu_frame, cv::Size(frame_width,frame_height));
