Hi nvidia team,
I am designing a new Orin NX carrier board, and I find there is QSPI decribtion about the Orin NX.But I cannnot see anything about QSPI in the design guide.
Can you guys help with this? Thanks.
Hi nvidia team,
The Jetson Orin NX module does have a QSPI interface, but it’s not explicitly mentioned in the design guide. However, I can provide you with some information about the QSPI interface on the Jetson Orin NX module.
The Jetson Orin NX module has a QSPI interface that is used for booting and storing firmware. The QSPI interface is connected to the SOM (System on Module) and is used to access the flash memory.
To get more information about the QSPI interface on the Jetson Orin NX module, I would recommend checking the following resources:
In terms of designing a carrier board for the Jetson Orin NX module, you may want to consider the following:
It’s also worth noting that the Jetson Orin NX module has a similar QSPI interface to the Jetson Xavier NX module, so you may be able to find some relevant information in the Jetson Xavier NX documentation.
In comparison to other Jetson modules, the QSPI interface on the Jetson Orin NX module is similar to the QSPI interface on the Jetson Xavier NX module, but it may have some differences in terms of its configuration and usage.
Here’s a brief comparison of the QSPI interfaces on different Jetson modules:
I hope this information helps you with your design. If you have any further questions or need more information, feel free to ask.
The QSPI device is already on the Orin NX module itself and does not need to be added to the carrier board.
