wuxu12
February 14, 2023, 3:10am
1
When I use:
import omni.graph.core as og
keys = og.Controller.Keys ,keys.CREATE_NODES:
[(“publishTransformTree”,“omni.isaac.ros_bridge.ROS1PublishTransformTree”)]
keys.SET_VALUES: [
(“publishTransformTree.inputs:parentPrim”, self.stage.GetPrimAtPath(“/World”)),
(“publishTransformTree.inputs:targetPrims”, self.imulinkPrim,“bundle”),
or any other way, I just fail to set the value by Type (bundle),anyone help?
Hi @wuxu12 . I’m looking into this for you.
Hi @wuxu12 . The dev team says that we don’t really support setting a bundle as a value directly. You should use EXPOSE_PRIMS
and then connect to the exposed bundle on the resulting ReadPrimBundle
node.
Here’s an example:
og.Controller.edit(
"/TestGraph",
keys.CREATE_NODES: ("Inspector", "omni.graph.nodes.BundleInspector"),
keys.CREATE_PRIMS: ("TestPrim", prim_definition),
keys.EXPOSE_PRIMS: (og.Controller.PrimExposureType.AS_BUNDLE, "TestPrim", "TestBundle"),
keys.CONNECT: ("TestBundle.outputs_primBundle", "Inspector.inputs:bundle"),
system
Closed
March 30, 2023, 7:52pm
4
