How to use RDMA write on DPA memory?
I allocated memory on the DPU’s Arm side, and then used RDMA write on this memory in DPA. This works.
The steps are as follows:
1、Allocate memory from the host
2、Create an mmap
3、Export the mmap
4、Create an mmap from the export
5、Get the mmap handle from the export mmap
However, when I change the first step to allocate memory from DPA instead (use doca_dpa_mem_alloc()), the program gets stuck after performing RDMA, waiting indefinitely for the RDMA write to complete. I modified my program based on the DPA_all_to_all sample.
May I ask, when allocating memory on the DPA, is it unnecessary to export it for remote RDMA access?
Hi 1563901725,
After allocating memory on the DPA, you shold
  1. Register or export the DPA memory for remote access using the appropriate DOCA API (e.g., doca_dpa_mem_dev_export() or similar, depending on the version and context).
  2. Obtain the remote key (rkey) or exported handle and share it with the RDMA initiator.
  3. Use this handle/rkey in the RDMA operation to ensure the remote side can access the DPA-allocated memory.
For details, you can refer to article: https://docs.nvidia.com/doca/archive/doca-v2.2.1/dpa-subsystem-programming-guide/index.html
Regards,
Quanying
