I want to use .fx effect file that use off screen render target.The effect file have 2 passess . Do i need to create the off screen render target manually at my application? or does the scripting create the needed render target? Can you please provide me small demo application that uses effect file with 2 passess and use rendertarget .
Related topics
Topic | Replies | Views | Activity | |
SAS script and render target | 0 | 1148 | April 3, 2013 | |
WGL_NV_DX_interop help: example code | 0 | 1561 | September 22, 2013 | |
How to read DirextX texture from the device ? | 1 | 1233 | September 24, 2014 | |
Target Independent Rasterization under DirectX | 0 | 1688 | October 26, 2015 | |
using nvxio::Render to render off screen. | 3 | 812 | October 18, 2021 | |
Lightsource projecting a texture/image | 2 | 480 | September 19, 2022 | |
Direct X/ OpenGL 3D model capture | 0 | 2083 | September 24, 2014 | |
Render and save rendered image in USD Composer | 2 | 182 | September 30, 2024 | |
Create a LightMap with raytracing | 2 | 5656 | June 14, 2022 | |
Is there possibility to capture frame in direct mode? | 1 | 861 | October 12, 2017 |
