How to use ROI encoding on XavierNX
I want to use ROI encoding, and try it base on the tegra_multimedia_api/samples/01_video_encode.
I run the sample code as:
./video_encode input.yuv 1920 1080 H264 out.264 --eroi -roi roi.cfg --input-metadata
And the content of roi.cfg is just like:
3 -4 34 34 16 16 -5 70 70 18 18 -3 100 100 34 34
but I found that all Qps are the same in a frame in file out.264, it means ROI doesn’t take effect, so what should I do? Thanks.roi.zip (194 Bytes)
Please attach roi.cfg for our reference.
Attached the roi.cfg, thanks. roi.zip (194 Bytes)
I am facing exactly the same problem.
Do I have to set any other options like vbr?
Hi @DaneLLL any updates on this issue? Would you be able to provide a minimum working example of the ROI encoding working with H.265?
Our teams are checking the issue. Will update once there is progress.
Please upgrade to JetPack 4.5.1 and give it a try.
