How to use secondary detector with deepstream 5.0 python apps
Hello, I am using Deepsteam 5.0 (python apps) with my custom yolov3 tiny weights to detect objects from a video with the primary detector. my question is how can i use secondary detector and what changes has to be made in python program to run secondary detector which is a yolo model.
thanks in Advance
Moving to DeepStream SDK forum for resolution.
• DeepStream Version
• TensorRT Version
Platform - Jetson Nano
Deepstream SDK - 5.0
TensorRT - 7+
I know back to back detector is used for secondary detection in a C++ example. how to use back to back detectors in python. and why is back to back detector example so slow on Jetson nano? or am I doing something wrong.
Refer to Is threre a python implementation of back-to-back detector? in deepstream 5.0
What do you mean slow? 1 fps?
Yes 2-3 fps at max. It stutters once it finds a car and then again stutters to find a numberplate. And why can I only pass a .h264 file and not a MP4 file
refer to https://github.com/NVIDIA-AI-IOT/deepstream_tlt_apps#measure-the-inference-perf to measure the model infernce perf .
Did you boost NANO clock with below two commands before measuring the perf?
sudo nvpmodel -m 0
sduo jetson_clocks
to support mp4, you need to add “qtdemux” between filesrc and h264(5)parser, e.g.
gst-launch-1.0 filesrc location=“a.mp4” ! qtdemux ! h264parse ! nvv4l2decoder …
Thanks, I’ll do that.
