Hi all,
I’m currently learning CUDA Fortran and have a specific challenge related to optimizing a kernel function with shared memory. The kernel I’m working with involves copying data from a (31, 64, 5)
array to a (64, 64, 5)
array.
Here is the kernel code that I’m working with:
fortran
复制代码
attributes(global) SUBROUTINE copyx(ABDENS, ABXMOM, ABYMOM, ABENER,
AADENS, AAXMOM, AAYMOM, AAENER)
REAL*8:: ABDENS(31, 64, 5), ABXMOM(31, 64, 5), ABYMOM(31, 64, 5), ABENER(31, 64, 5)
REAL*8:: AADENS(64, 64, 5), AAXMOM(64, 64, 5), AAYMOM(64, 64, 5), AAENER(64, 64, 5)
INTEGER:: IX, IY, IZ, XI
IX = (blockIdx%x - 1) * blockDim%x + threadIdx%x
IY = (blockIdx%y - 1) * blockDim%y + threadIdx%y
IF (IY >= 3 .AND. IY <= 62) THEN
IF (IX >= 2 .AND. IX <= 62) THEN
XI = IX / 2
DO IZ = 1, 5
AADENS(IX, IY, IZ) = ABDENS(XI, IY, IZ)
AAXMOM(IX, IY, IZ) = ABXMOM(XI, IY, IZ)
AAYMOM(IX, IY, IZ) = ABYMOM(XI, IY, IZ)
AAENER(IX, IY, IZ) = ABENER(XI, IY, IZ)
END DO
CALL syncthreads()
END IF
END IF
END SUBROUTINE copyx
The problem is, I’m trying to optimize this kernel by using shared memory to avoid redundant global memory accesses. I’ve learned how to use shared memory, but I’m not sure how to implement it in this kernel. Specifically, I want to load blocks of data into shared memory and then perform the assignment to the output arrays from there.
Could anyone help me with how to modify this kernel to use shared memory effectively? Any guidance on using shared memory for the input and output arrays would be much appreciated!
Thanks in advance!
You can copy this and post it on your forum to get help with your issue. It explains your problem clearly and gives context for what you’re trying to achieve.
