How to use softwareimages as created on another cluster
Hi Folks
I have to use my softwareimages on another cluster.
I copied /cm/images/<my softwareimage> but it is not registered in BCM on another cluster
  • BCM is the same version 9.1
  • Can I export softwareimages and import it to another cluster?
    Is there a way in either cmsh or webUI?
  • How do you usually backup your softwareimages?
If the image directory is already present on the new cluster, you can register it in the Bright configuration using cm-create-image as follows:
# cm-create-image -d /cm/images/<my softwareimage> -n <image name>
Others in the community can answer with how they perform backups, but Bright has no official mechanism for backing up software images.
