How to use ssh under DRIVE Software 10.0?
Currently, I just upgraded my Xavier from DRIVE Software 9.0 to 10.0. However, I found that there is no firefox browser to surf internet. Under SDK 10.0, when I try to use ssh to log into my server, it shows “ssh: connect to host 192.168.1.11 port 22: Connection timed out”. How to correctly set ssh and use scp to copy my files from server to Xavier under DRIVE Software 10.0? SDK 10.0 seems totally different with SDK 9.0. Thanks
Dear ray.di,
Did you set up the networking in target and able to ping? Please check https://docs.nvidia.com/drive/drive_os_5.1.6.1L/nvvib_docs/index.html#page/DRIVE_OS_Linux_SDK_Development_Guide/Architecture/config_network_setup.html#
Dear Siva, Thanks for your great helps!! It can work now.
Dear Siva,
Going through the networking set up described in comment #2 works well and I’m able to ping the target and connect through SSH from host.
However, even if am connected to the host, I do not have any internet access from the target ; any idea where the issue could come from ?
regards
Dear asnts,
Did you check https://devtalk.nvidia.com/default/topic/1056261/general/ethernet-connection-for-drive-agx/post/5359652/#5359652
