Is it possible to use custom sensor with DriveWorks sample application?
I added Sony sensors to libnv_extdev.so and confirmed that it works fine
with NvMedia sample applications such as ipp_raw.
Similarly, I would like to use custom sensor with sample_drivenet, sample_camera_gmsl_raw etc.
Please let me know any useful information.
(reference material, source code to be changed, etc)
Thank you and best regards,
Nissy
Dear Naoki.Nishimura,
We’ve posted new PDK and DW on developer.com.
So could you please update PDK and DW?
And then please refer to /usr/local/driveworks-1.2/doc/nvdwx_html/dwx_camera_gmsl_samples.html.
DriveWorks all source codes are in /usr/local/driveworks-1.2/samples/src/ on Host PC. Thanks.
Dear SteveNV,
Thank you for your reply.
I downloaded “sdkmanager-0.9.8.2002.zip” on Ubuntu 16.04 LTS PC.
Then I started sdkmanager with reference to the user guide.
I select DEVZONE on the login screen and enter the mail address and password,
the screen of Step01 will not be displayed after the input form disappears.
Could you teach me what is wrong, please?
Nissy
Could you please check your company network environment if in network environments that require a proxy server to access the Internet? Thanks.
Dear SteveNV,
I checked the network environment and it worked normally.
I also found a description about support for custom sensors in the document of driveworks 1.2.
I will try with reference to the description.
Nissy
