I tried for a long time, but I couldn’t successfully use the Print RTX Lidar Print Info Node or new version named Isaac Print RTX Sensor Info Omnigraph. I think the root cause is that I don’t know how to pass the correct data to the RTX sensor render result
These are the two Omnigraphs I tried, and I couldn’t get the Sensor Info.
I don’t understand what a render result is and where to get it.
Looking forward to any useful help. Thanks!
