I’m trying to use the Reference Picture Selection(RPS) mode for video encoding. My goal is to set the long-term reference frame (LTR frame) as the reference, instead of using the previous frame as the reference.
The default mode: frame 1 is I frame, frame 2 uses frame 1 as the reference frame, frame 3 uses frame 2 as the reference frame, frame 4 uses frame 3 as the reference frame, frame 5 uses frame 4 as the reference frame…
What I want: frame 1 is I frame, frame 2 is an I frame as well, then frame 3 uses frame 1 as reference frame, then frame 4 uses frame 2 as the reference frame, then frame 5 uses frame 3 as the reference frame, then frame 6 uses frame 4 as reference frame…
The video encodes sample project can let me input a file contains the rps parameter file.
-rpsf <rps_file_path> Specify external rps param file
However, it is very hard to understand how to use the RPS mode. The rps mode provides these parameters to set:
typedef struct v4l2_enc_frame_ext_rps_ctrl_params_
/** unique Id of current frame. */
__u32 nFrameId;
/** Boolean value indicating if current frame referenced or non-referenced. */
__u8 bRefFrame;
/** Boolean value indicating if current frame long Term Ref Flag. */
__u8 bLTRefFrame;
/** Max Number of reference frames to use for inter-motion search. */
__u32 nMaxRefFrames;
/** # of valid entries in RPS, 0 means IDR. */
__u32 nActiveRefFrames;;
/** frame id of reference frame to be used for motion search, ignored for IDR. */
__u32 nCurrentRefFrameId;
/** Array of RPS */
v4l2_enc_frame_prop RPSList[V4L2_MAX_REF_FRAMES];
}v4l2_enc_frame_ext_rps_ctrl_params;
I tried several numbers but all of them fails. For my use case, how should I set for each frame?
Or could you provide me with a sample file that uses the long-term reference frame in this mode?
Thank you so much!
