How to use the suface avaiables in PTX?
This`s the part descript of PTX docments:
The surface (.surf) state space is similar to global memory, but is 2D in nature.  It takes a 2D
address (i and j components), and with respect to cache, spatial locality generally works well
in a 2D neighborhood.  This allows tiled decompositions to perform quite well.
it seems that should use it like :
.surf .f32 surfVar;
mov.f32 $r0,surfVar[0][3];
and at the end of sections 5.3.1:
Note that texture and surface variables do not have an associated type and size.
but through up descript it seems should be used as:
.surf[7][4].u32 surfVar;
Which is right?
thanks!
According to section 10.5.2 of PTX documentation, declarations and instructions using .surf space are not supported. So I guess you don’t really need the answer.
O?That`s very helpless External Image
