I would like to manipulate a cube in Isaac Sim by ROS.
There is a tool called “ROS_Teleport”. It seems that it can help me to move objects in Isaac Sim by ROS.
After adding it into the Isaac Sim. I select a Cube as teleportPrims and start the simulation.
By using the rosservice list. I can saw there’s a rosservice called “teleport_pose” is running.
Then, I typed in the command below in a terminal.
rosservice call /teleport_pos "header:
seq: 0
stamp: {secs: 0, nsecs: 0}
frame_id: 'Cube'
names: ['Cube']
poses:
- position: {x: 0.0, y: 0.0, z: 0.1}
orientation: {x: 0.0, y: 0.0, z: 0.0, w: 0}
velocities:
- linear: {x: 0.0, y: 0.0, z: 0.0}
angular: {x: 0.0, y: 0.0, z: 0.0}
scales:
- {x: 1.0, y: 1.0, z: 1.0}"
And it returns an error
ERROR: service [/teleport_pos] responded with an error: b''
And of cource the cube doesn’t move in Isaac Sim.
Does any one understand how to use the service correctly?
Please help.
