How to use trained yolov7 tiny
• Hardware Platform (Jetson / GPU) Jetson xavier
• DeepStream Version 6.0.1
• JetPack Version (valid for Jetson only) 4.6.1
• TensorRT Version 8.2
I want to create wts and cfg files using the trained yolov7-tiny model.
However, it cannot be converted through gen_wts_yoloV7.py provided by Deepstream-Yolo .(GitHub - marcoslucianops/DeepStream-Yolo: NVIDIA DeepStream SDK 6.2 / 6.1.1 / 6.1 / 6.0.1 / 6.0 implementation for YOLO models)
An error occurs because child._get_name() is IDetect in gen_wts_yoloV7.py. Currently there is only Detect in this file. how can i solve it?
[yolov7-tiny train cfg]
parameters
nc: 1 # number of classes
depth_multiple: 1.0 # model depth multiple
width_multiple: 1.0 # layer channel multiple
anchors
anchors:
  • [10,13, 16,30, 33,23] # P3/8
  • [30,61, 62,45, 59,119] # P4/16
  • [116,90, 156,198, 373,326] # P5/32
yolov7-tiny backbone
backbone:
[from, number, module, args] c2, k=1, s=1, p=None, g=1, act=True
[[-1, 1, Conv, [32, 3, 2, None, 1, nn.LeakyReLU(0.1)]], # 0-P1/2
[-1, 1, Conv, [64, 3, 2, None, 1, nn.LeakyReLU(0.1)]], # 1-P2/4
[-1, 1, Conv, [32, 1, 1, None, 1, nn.LeakyReLU(0.1)]],
[-2, 1, Conv, [32, 1, 1, None, 1, nn.LeakyReLU(0.1)]],
[-1, 1, Conv, [32, 3, 1, None, 1, nn.LeakyReLU(0.1)]],
[[-1, -2, -3, -4], 1, Concat, [1]],
[-1, 1, Conv, [64, 1, 1, None, 1, nn.LeakyReLU(0.1)]], # 7
[-1, 1, MP, ], # 8-P3/8
[-2, 1, Conv, [64, 1, 1, None, 1, nn.LeakyReLU(0.1)]],
[-1, 1, Conv, [64, 3, 1, None, 1, nn.LeakyReLU(0.1)]],
[-1, 1, Conv, [128, 1, 1, None, 1, nn.LeakyReLU(0.1)]], # 14
[-1, 1, MP, ], # 15-P4/16
[-2, 1, Conv, [128, 1, 1, None, 1, nn.LeakyReLU(0.1)]],
[-1, 1, Conv, [128, 3, 1, None, 1, nn.LeakyReLU(0.1)]],
[-1, 1, Conv, [256, 1, 1, None, 1, nn.LeakyReLU(0.1)]], # 21
[-1, 1, MP, ], # 22-P5/32
[-2, 1, Conv, [256, 1, 1, None, 1, nn.LeakyReLU(0.1)]],
[-1, 1, Conv, [256, 3, 1, None, 1, nn.LeakyReLU(0.1)]],
[-1, 1, Conv, [512, 1, 1, None, 1, nn.LeakyReLU(0.1)]], # 28
yolov7-tiny head
head:
[[-1, 1, Conv, [256, 1, 1, None, 1, nn.LeakyReLU(0.1)]],
[-1, 1, SP, [5]],
[-2, 1, SP, [9]],
[-3, 1, SP, [13]],
[[-1, -7], 1, Concat, [1]],
[-1, 1, Conv, [256, 1, 1, None, 1, nn.LeakyReLU(0.1)]], # 37
[-1, 1, nn.Upsample, [None, 2, ‘nearest’]],
[21, 1, Conv, [128, 1, 1, None, 1, nn.LeakyReLU(0.1)]], # route backbone P4
[[-1, -2], 1, Concat, [1]],
[-1, 1, Conv, [128, 1, 1, None, 1, nn.LeakyReLU(0.1)]], # 47
[14, 1, Conv, [64, 1, 1, None, 1, nn.LeakyReLU(0.1)]], # route backbone P3
[-1, 1, Conv, [64, 1, 1, None, 1, nn.LeakyReLU(0.1)]], # 57
[-1, 1, Conv, [128, 3, 2, None, 1, nn.LeakyReLU(0.1)]],
[[-1, 47], 1, Concat, [1]],
[-1, 1, Conv, [128, 1, 1, None, 1, nn.LeakyReLU(0.1)]], # 65
[-1, 1, Conv, [256, 3, 2, None, 1, nn.LeakyReLU(0.1)]],
[[-1, 37], 1, Concat, [1]],
[-1, 1, Conv, [256, 1, 1, None, 1, nn.LeakyReLU(0.1)]], # 73
[57, 1, Conv, [128, 3, 1, None, 1, nn.LeakyReLU(0.1)]],
[65, 1, Conv, [256, 3, 1, None, 1, nn.LeakyReLU(0.1)]],
[73, 1, Conv, [512, 3, 1, None, 1, nn.LeakyReLU(0.1)]],
[[74,75,76], 1, IDetect, [nc, anchors]], # Detect(P3, P4, P5)
[gen_wts_yoloV7.py]
import argparse
import os
import struct
import torch
from utils.torch_utils import select_device
class Layers(object):
def init(self, n, size, fw, fc):
self.blocks = [0 for _ in range(n)]
self.current = 0
    self.width = size[0] if len(size) == 1 else size[1]
    self.height = size[0]
    self.num = 0
    self.nc = 0
    self.anchors = ''
    self.masks = []
    self.fw = fw
    self.fc = fc
    self.wc = 0
    self.net()
def ReOrg(self, child):
    self.current = child.i
    self.fc.write('\n# ReOrg\n')
    self.reorg()
def Conv(self, child):
    self.fc.write('\n# Conv\n')
    if child.f != -1:
        r = self.get_route(child.f)
        self.route('%d' % r)
    self.convolutional(child)
def DownC(self, child):
    self.fc.write('\n# DownC\n')
    self.maxpool(child.mp)
    self.convolutional(child.cv3)
    self.route('-3')
    self.convolutional(child.cv1)
    self.convolutional(child.cv2)
    self.route('-1, -4')
def MP(self, child):
    self.fc.write('\n# MP\n')
    self.maxpool(child.m)
def SP(self, child):
    self.fc.write('\n# SP\n')
    if child.f != -1:
def SPPCSPC(self, child):
    self.fc.write('\n# SPPCSPC\n')
    self.route('-2')
    self.convolutional(child.cv4)
    self.maxpool(child.m[0])
    self.route('-2')
    self.maxpool(child.m[1])
    self.route('-4')
    self.maxpool(child.m[2])
    self.route('-6, -5, -3, -1')
    self.convolutional(child.cv5)
    self.convolutional(child.cv6)
    self.route('-1, -13')
    self.convolutional(child.cv7)
def RepConv(self, child):
    self.fc.write('\n# RepConv\n')
    if child.f != -1:
    self.convolutional(child.rbr_1x1)
    self.route('-2')
    self.convolutional(child.rbr_dense)
    self.shortcut(-3, act=self.get_activation(child.act._get_name()))
def Upsample(self, child):
    self.fc.write('\n# Upsample\n')
    self.upsample(child)
def Concat(self, child):
    self.fc.write('\n# Concat\n')
    r = []
    for i in range(1, len(child.f)):
        r.append(self.get_route(child.f[i]))
    self.route('-1, %s' % str(r)[1:-1])
def Shortcut(self, child):
    self.fc.write('\n# Shortcut\n')
    r = self.get_route(child.f[1])
    self.shortcut(r)
def Detect(self, child):
    self.fc.write('\n# Detect\n')
    self.get_anchors(child.state_dict(), child.m[0].out_channels)
    for i, m in enumerate(child.m):
        r = self.get_route(child.f[i])
        self.convolutional(m, detect=True)
        self.yolo(i)
def net(self):
    self.fc.write('[net]\n' +
                  'width=%d\n' % self.width +
                  'height=%d\n' % self.height +
                  'channels=3\n' +
                  'letter_box=1\n')
def reorg(self):
    self.blocks[self.current] += 1
    self.fc.write('\n[reorg]\n')
def convolutional(self, cv, act=None, detect=False):
    self.get_state_dict(cv.state_dict())
    if cv._get_name() == 'Conv2d':
        filters = cv.out_channels
        size = cv.kernel_size
        stride = cv.stride
        pad = cv.padding
        groups = cv.groups
        bias = cv.bias
        bn = False
        act = 'linear' if not detect else 'logistic'
    elif cv._get_name() == 'Sequential':
        filters = cv[0].out_channels
        size = cv[0].kernel_size
        stride = cv[0].stride
        pad = cv[0].padding
        groups = cv[0].groups
        bias = cv[0].bias
        bn = True if cv[1]._get_name() == 'BatchNorm2d' else False
        act = 'linear'
    else:
        filters = cv.conv.out_channels
        size = cv.conv.kernel_size
        stride = cv.conv.stride
        pad = cv.conv.padding
        groups = cv.conv.groups
        bias = cv.conv.bias
        bn = True if hasattr(cv, 'bn') else False
        if act is None:
            act = self.get_activation(cv.act._get_name()) if hasattr(cv, 'act') else 'linear'
    b = 'batch_normalize=1\n' if bn is True else ''
    g = 'groups=%d\n' % groups if groups > 1 else ''
    w = 'bias=1\n' if bias is not None and bn is not False else 'bias=0\n' if bias is None and bn is False else ''
    self.fc.write('\n[convolutional]\n' +
                  b +
                  'filters=%d\n' % filters +
                  'size=%s\n' % self.get_value(size) +
                  'stride=%s\n' % self.get_value(stride) +
                  'pad=%s\n' % self.get_value(pad) +
                  g +
                  w +
                  'activation=%s\n' % act)
def route(self, layers):
    self.fc.write('\n[route]\n' +
                  'layers=%s\n' % layers)
def shortcut(self, r, act='linear'):
    self.fc.write('\n[shortcut]\n' +
                  'from=%d\n' % r +
def maxpool(self, m):
    stride = m.stride
    size = m.kernel_size
    mode = m.ceil_mode
    m = 'maxpool_up' if mode else 'maxpool'
    self.fc.write('\n[%s]\n' % m +
                  'stride=%d\n' % stride +
                  'size=%d\n' % size)
def upsample(self, child):
    stride = child.scale_factor
    self.fc.write('\n[upsample]\n' +
                  'stride=%d\n' % stride)
def yolo(self, i):
    self.fc.write('\n[yolo]\n' +
                  'mask=%s\n' % self.masks[i] +
                  'anchors=%s\n' % self.anchors +
                  'classes=%d\n' % self.nc +
                  'num=%d\n' % self.num +
                  'scale_x_y=2.0\n' +
                  'new_coords=1\n')
def get_state_dict(self, state_dict):
    for k, v in state_dict.items():
        if 'num_batches_tracked' not in k:
            vr = v.reshape(-1).numpy()
            self.fw.write('{} {} '.format(k, len(vr)))
            for vv in vr:
                self.fw.write(' ')
                self.fw.write(struct.pack('>f', float(vv)).hex())
            self.fw.write('\n')
            self.wc += 1
def get_anchors(self, state_dict, out_channels):
    anchor_grid = state_dict['anchor_grid']
    aa = anchor_grid.reshape(-1).tolist()
    am = anchor_grid.tolist()
    self.num = (len(aa) / 2)
    self.nc = int((out_channels / (self.num / len(am))) - 5)
    self.anchors = str(aa)[1:-1]
    n = 0
    for m in am:
        mask = []
        for _ in range(len(m)):
            mask.append(n)
            n += 1
        self.masks.append(str(mask)[1:-1])
def get_value(self, key):
    if type(key) == int:
        return key
    return key[0] if key[0] == key[1] else str(key)[1:-1]
def get_route(self, n):
    r = 0
    if n < 0:
        for i, b in enumerate(self.blocks[self.current-1::-1]):
            if i < abs(n) - 1:
                r -= b
            else:
                break
    else:
        for i, b in enumerate(self.blocks):
            if i <= n:
                r += b
            else:
                break
    return r - 1
def get_activation(self, act):
    if act == 'Hardswish':
        return 'hardswish'
    elif act == 'LeakyReLU':
        return 'leaky'
    elif act == 'SiLU':
        return 'silu'
    return 'linear'
def parse_args():
parser = argparse.ArgumentParser(description=‘PyTorch YOLOv7 conversion’)
parser.add_argument(‘-w’, ‘–weights’, required=True, help=‘Input weights (.pt) file path (required)’)
‘-s’, ‘–size’, nargs=‘+’, type=int, help=‘Inference size [H,W] (default [640])’)
parser.add_argument(“–p6”, action=“store_true”, help=“P6 model”)
args = parser.parse_args()
if not os.path.isfile(args.weights):
raise SystemExit(‘Invalid weights file’)
if not args.size:
args.size = [1280] if args.p6 else [640]
return args.weights, args.size
pt_file, inference_size = parse_args()
model_name = os.path.basename(pt_file).split(‘.pt’)[0]
wts_file = model_name + ‘.wts’ if ‘yolov7’ in model_name else ‘yolov7_’ + model_name + ‘.wts’
cfg_file = model_name + ‘.cfg’ if ‘yolov7’ in model_name else ‘yolov7_’ + model_name + ‘.cfg’
device = select_device(‘cpu’)
model = torch.load(pt_file, map_location=device)
model = model[‘ema’ if model.get(‘ema’) else ‘model’].float()
anchor_grid = model.model[-1].anchors * model.model[-1].stride[…, None, None]
delattr(model.model[-1], ‘anchor_grid’)
model.model[-1].register_buffer(‘anchor_grid’, anchor_grid)
model.to(device).eval()
with open(wts_file, ‘w’) as fw, open(cfg_file, ‘w’) as fc:
layers = Layers(len(model.model), inference_size, fw, fc)
for child in model.model.children():
    if child._get_name() == 'ReOrg':
        layers.ReOrg(child)
    elif child._get_name() == 'Conv':
        layers.Conv(child)
    elif child._get_name() == 'DownC':
        layers.DownC(child)
    elif child._get_name() == 'MP':
        layers.MP(child)
    elif child._get_name() == 'SP':
        layers.SP(child)
    elif child._get_name() == 'SPPCSPC':
        layers.SPPCSPC(child)
    elif child._get_name() == 'RepConv':
        layers.RepConv(child)
    elif child._get_name() == 'Upsample':
        layers.Upsample(child)
    elif child._get_name() == 'Concat':
        layers.Concat(child)
    elif child._get_name() == 'Shortcut':
        layers.Shortcut(child)
    elif child._get_name() == 'Detect':
        layers.Detect(child)
    else:
        raise SystemExit('Model not supported')
os.system(‘echo “%d” | cat - %s > temp && mv temp %s’ % (layers.wc, wts_file, wts_file))
This issue would be outside of Deepstream, You could try asking the author, and please refer to NVIDIA official sample yolo_deepstream.
You have to reparameterize your weight(.pt) file prior to use the gen_wts_yolov7.py. Follow this guide: DeepStream-Yolo/YOLOv7.md at master · marcoslucianops/DeepStream-Yolo · GitHub
In step 4 you will notice it sends you to the reparam page where it has all of the options but Tiny which is what you need. Simply change all of the 105’s in the regular yolov7 param method(the method at the top) to 77.
@tjwhitten25 thanks for sharing, @min_sunyoung please refer to this.
