• Hardware Platform (Jetson)
• DeepStream Version:6.0
• JetPack Version (valid for Jetson only):4.6
• TensorRT Version
hi, guy,
I want to use udp when pull rtsp stream, I set select-rtp-protocol equal 0, but it is not useful.
how to set parameters?
What is your RTSP server settings? Is it UDP or TCP? DeepStream source is the RTSP client, you should set the client according to the server.
The server is camera which produced by uniview.
The camera support botch tcp and udp.
The ffmpeg can pull by tcp and udp. but deepstream only support tcp.
I want to pull the stream by udp, what can I do?
In create_rtsp_src_bin() function in /opt/deepstream/deepstream/sources/apps/apps-common/src/deepstream_source_bin.c, only “4” or “7” is set to rtspstc " protocols" property. You can modify the code and rebuild the deepstream-app to enable UDP only configuration.
https://gstreamer.freedesktop.org/documentation/rtsp/rtspsrc.html?gi-language=c#rtspsrc:protocols
