How to use wired network in orin?
The wired network does not work when I plug wire to orin?
How to set it?
Are you using JetPack 5.0.2 GA release?
If not, please upgrade to this new version to try agian.
Actually, we didn’t hear similar issue on AGX Orin devkit unless you’re using custom carrier board which hasn’t been brought up successfully.
OK, I have solved this problem by following command.
apt dist-upgrade
