How to using jetson xavier NX with high preformance
Hi, My friend told me that I should NOT turn off Jetson Xavier NX when I finish my job in the end of the day. The better way to use jetson xavier NX that always keep it on and the next day I continues.
I have a little bit confuse because some kind super computer almost never shut down.
So do you have any recommend to use Jetson Xavier NX ? Should I shut down it every day? any short explain with you recommend
hello nguyenngocdat1995,
may I know what’s the theory?
please refer to developer guide, you should check Supported Modes and Power Efficiency.
it’s by default running at 10W mode, (i.e. mode-3). you should use the nvpmodel or the user-interface on the top to change the available power modes.
thanks
