Minicom output of flashing to eMMC. Notice the hostname. It is now as expected.
[0072.437] W> RATCHET: MB1 binary ratchet value 4 is larger than ratchet level 2 from HW fuses.
[0072.445] I> MB1 (prd-version: 2.5.0.0-t194-41334769-d9272b5a)
[0072.451] I> Boot-mode: Platform RCM
[0072.454] I> Platform: Silicon
[0072.457] I> Chip revision : A02P
[0072.460] I> Bootrom patch version : 15 (correctly patched)
[0072.465] I> ATE fuse revision : 0x200
[0072.468] I> Ram repair fuse : 0x0
[0072.471] I> Ram Code : 0x2
[0072.474] I> rst_source: 0x0, rst_level: 0x0
[0072.479] I> USB configuration success
[0074.672] I> mb2 image downloaded
[0074.755] I> Recovery boot mode 0
[0074.761] I> UPHY full init done
[0074.768] I> MB1 done
[0074.773] I> Welcome to MB2(TBoot-BPMP) Applet (version: default.t194-mobile-4ae695b2)
[0074.780] I> DMA Heap @ [0x40020000 - 0x40065800]
[0074.785] I> Default Heap @ [0xd486400 - 0xd48a400]
[0074.789] W> Profiler not initialized
[0074.848] I> sdmmc DDR50 mode
[0074.852] E> SPI_FLASH: Invalid value device id: 7.
[0074.857] I> QSPI Flash is not present.
[0074.863] E> CLK_RST: instance 6 not found in module 44.
[0074.868] E> MPhy CAR configuration failed error = 1747992077
[0074.874] E> UFS initialization failed
[0074.877] I> UFS is not present
[0074.883] I> Found 20 partitions in SDMMC_BOOT (instance 3)
[0074.893] I> Found 44 partitions in SDMMC_USER (instance 3)
[0074.898] W> Profiler not initialized
[0074.901] I> Entering 3p server
[0074.904] I> USB configuration success
[0075.984] I> Populate chip info
[0076.028] I> Populate eeprom info
[0076.032] I> Populate eeprom info for module cvm
[0076.037] > DEVICE_PROD: device prod is not initialized.
[0076.160] I> Rebooting : reboot-recovery
[0076.164] I> Reset to recovery mode
[0160.422] W> RATCHET: MB1 binary ratchet value 4 is larger than ratchet level 2 from HW fuses.
[0160.430] I> MB1 (prd-version: 2.5.0.0-t194-41334769-d9272b5a)
[0160.436] I> Boot-mode: RCM
[0160.438] I> Platform: Silicon
[0160.441] I> Chip revision : A02P
[0160.444] I> Bootrom patch version : 15 (correctly patched)
[0160.449] I> ATE fuse revision : 0x200
[0160.453] I> Ram repair fuse : 0x0
[0160.456] I> Ram Code : 0x2
[0160.459] I> rst_source: 0xb, rst_level: 0x1
[0160.464] I> USB configuration success
[0162.505] I> bct_bootrom image downloaded
[0162.514] W> PROD_CONFIG: device prod data is empty in MB1 BCT.
[0162.521] I> Temperature = 31500
[0162.524] W> Skipping boost for clk: BPMP_CPU_NIC
[0162.528] W> Skipping boost for clk: BPMP_APB
[0162.532] W> Skipping boost for clk: AXI_CBB
[0162.536] W> Skipping boost for clk: AON_CPU_NIC
[0162.541] W> Skipping boost for clk: CAN1
[0162.544] W> Skipping boost for clk: CAN2
[0162.549] I> Boot-device: SDMMC (instance: 3)
[0162.553] I> bct_mb1 image downloaded
[0162.563] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0162.571] W> Thermal config not found in BCT
[0162.579] W> MEMIO rail config not found in BCT
[0162.595] I> bct_mem image downloaded
[0165.061] I> blob image downloaded
[0165.152] I> Recovery boot mode 0
[0165.196] W> Platform config not found in BCT
[0165.229] I> MB1 done
����main enter
SPE VERSION #: R01.00.18 Created: Jan 29 2021 @ 14:18:27
HW Function test
Start Scheduler.
in late init
[0165.240] I> Welcome to MB2(TBoot-BPMP) Recovery (version: default.t194-mobile-3b3b81d4)
[0165.240] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0165.241] I> Default Heap @ [0xd486400 - 0xd48a400]
[0165.243] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0165.248] W> device prod register failed
[0165.263] I> Relocating BR-BCT
[0165.265] > DEVICE_PROD: device prod is not initialized.
[0165.290] E> I2C: slave not found in slaves.
[0165.291] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0165.292] E> I2C_DEV: Failed to send register address 0x00000000.
[0165.293] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
[0165.293] E> eeprom: Failed to read I2C slave device
[0165.297] I> Failed to read CVB eeprom data @ AE
[0165.301] I> Retrying CVB eeprom read @ AC ...
[0165.336] I> Relocating OP-TEE dtb from: 0x6bfffc10 to 0x70050000, size: 1008
[0165.337] I> [0] START: 0x80000000, SIZE: 0x47cf0000
[0165.338] I> [1] START: 0xca000000, SIZE: 0x800000
[0165.338] I> dram_block larger than 80000000
[0165.338] I> [2] START: 0x100000000, SIZE: 0x780000000
[0165.343] I> Setting NS memory ranges to OP-TEE dtb finished.
[0165.346] I> found decompressor handler: lz4
[0165.916] I> EKB detected (length: 0x410) @ VA:0x526fa200
[0165.918] I> Setting EKB blob info to OPTEE dtb finished.
��NOTICE: BL31: v2.6(release):6363e7382
NOTICE: BL31: Built : 15:09:29, Jan 24 2023
I/TC:
��I/TC: Non-secure external DT found
��bpmp: init
bpmp: tag is 128431eec76692047e1ac1ebc0392266
sku_dt_init: not sku 0x00
clk_early initialized
mail_early initialized
fuse initialized
hwwdt initialized
t194_ec_get_ec_list: found 45 ecs
ec initialized
vmon_setup_monitors: found 3 monitors
vmon initialized
adc initialized
fmon_populate_monitors: found 73 monitors
��I/TC: OP-TEE version: 3.1��fmon initialized
mc initialized
��9 ��reset initialized
nvhs initialized
uphy_early initialized
emc_early initialized
��(gcc version 9.3.0 (Buildroot 2020.08)) #2 Tue Jan 24 23:20:42 UTC 2023 aarch64
I/T��392 clocks registered
��C: WARNING: This OP-TEE configuration mi��clk initialized
��g��io_dpd initialized
��h��thermal initialized
thermal_mrq initialized
��t be insec��i2c initialized
��u��vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
vrmon initialized
��re!
I/TC: ��regulator initialized
��WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
��avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
suspend initialized
pg_late initialized
pg_mrq_init initialized
strap initialized
nvl initialized
emc initialized
emc_mrq initialized
clk_dt initialized
tj_init initialized
/uphy is not enabled status = disabled
uphy_dt initialized
uphy_mrq initialized
uphy initialized
ec_swd_poll_start: 281 reg polling start w period 47 ms
ec_late initialized
hwwdt_late initialized
reset_mrq initialized
ec_mrq initialized
fmon_mrq initialized
clk_mrq initialized
avfs_mrq initialized
mail_mrq initialized
i2c_mrq initialized
tag_mrq initialized
console_mrq initialized
mrq initialized
clk_sync_fmon_post initialized
clk_dt_late initialized
noc_late initialized
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
avfs_clk_mach_post initialized
avfs_clk_platform_post initialized
cvc_late initialized
regulator_post initialized
rm initialized
console_late initialized
clk_dt_post initialized
mc_reg initialized
pg_post initialized
profile initialized
fuse_late initialized
extras_post initialized
bpmp: init complete
entering main console loop
] ��I/TC: Primary CPU switching to normal world boot
[0166.614] I> Welcome to TBoot-CPU Recovery
[0166.615] I> Heap: [0xa0f00000 ... 0xa9f00000
[0166.615] I> gpio framework initialized
[0166.632] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0166.644] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0166.645] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0166.656] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0166.664] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0166.664] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0166.665] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0166.671] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0166.677] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0166.678] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0166.688] I> fixed regulator driver initialized
[0166.840] I> CPU: Nvidia Carmel
[0166.841] I> CPU: MIDR: 0x4e0f0040, MPIDR: 0x80000000
[0166.841] I> Platform: Silicon
[0166.841] I> chip revision : A02P
[0166.841] I> Boot_device: SDMMC_BOOT instance: 3
[0166.842] I> sdmmc-3 params source = boot args
[0167.286] I> sdmmc-3 params source = boot args
[0167.286] I> sdmmc bdev is already initialized
[0167.313] I> Found 20 partitions in SDMMC_BOOT (instance 3)
[0167.326] I> Found 44 partitions in SDMMC_USER (instance 3)
[0167.326] I> Recovery boot_type: 0
[0167.326] I> Entering 3p server
[0167.327] I> USB configuration success
[0167.490] I> Populate storage info
[0167.558] I> Erasing device 0: 3
[0168.682] I> Writing device 0: 3.
[0168.713] I> Found 20 partitions in SDMMC_BOOT (instance 3)
[0168.715] I> Erasing device 1: 3
[0169.387] I> Writing device 1: 3.
[0169.395] I> Writing device 1: 3.
[0169.415] I> Found 44 partitions in SDMMC_USER (instance 3)
[0169.416] I> Writing device 1: 3.
[0169.436] I> Found 44 partitions in SDMMC_USER (instance 3)
[0169.437] I> Writing mb1 partition.
[0169.553] I> Writing mb1_b partition.
[0169.589] I> Writing spe-fw partition.
[0169.602] I> Writing mb2 partition.
[0169.634] I> Writing mts-preboot partition.
[0169.655] I> Writing spe-fw_b partition.
[0169.747] I> Writing mb2_b partition.
[0169.859] I> Writing mts-preboot_b partition.
[0169.880] I> Writing VER_b partition.
[0169.895] I> Writing VER partition.
[0169.909] I> Writing device 1: 3.
[0169.917] I> Writing APP partition.
[0318.490] I> Writing mts-mce partition.
[0318.515] I> Writing mts-proper partition.
[0318.687] I> Writing cpu-bootloader partition.
[0318.847] I> Writing bootloader-dtb partition.
[0318.887] I> Writing secure-os partition.
[0318.943] I> Writing eks partition.
[0318.964] I> Writing bpmp-fw partition.
[0319.023] I> Writing bpmp-fw-dtb partition.
[0319.047] I> Writing xusb-fw partition.
[0319.059] I> Writing rce-fw partition.
[0319.101] I> Writing adsp-fw partition.
[0319.136] I> Writing sc7 partition.
[0319.158] I> Writing kernel partition.
[0321.021] I> Writing kernel-dtb partition.
[0321.058] I> Writing mts-mce_b partition.
[0321.083] I> Writing mts-proper_b partition.
[0321.253] I> Writing cpu-bootloader_b partition.
[0321.412] I> Writing bootloader-dtb_b partition.
[0321.452] I> Writing secure-os_b partition.
[0321.508] I> Writing eks_b partition.
[0321.529] I> Writing bpmp-fw_b partition.
[0321.588] I> Writing bpmp-fw-dtb_b partition.
[0321.611] I> Writing xusb-fw_b partition.
[0321.624] I> Writing rce-fw_b partition.
[0321.665] I> Writing adsp-fw_b partition.
[0321.699] I> Writing sc7_b partition.
[0321.721] I> Writing kernel_b partition.
[0323.612] I> Writing kernel-dtb_b partition.
[0323.646] I> Writing recovery partition.
[0325.713] I> Writing recovery-dtb partition.
[0325.748] I> Writing esp partition.
[0328.759] I> Writing secondary_gpt_backup partition.
[0328.806] I> Writing BCT partition.
[0328.979] I> Writing BCT-boot-chain_backup partition.
[0329.035] I> Writing MB1_BCT partition.
[0329.094] I> Writing MB1_BCT_b partition.
[0329.239] I> Writing MEM_BCT partition.
[0329.378] I> Writing MEM_BCT_b partition.
[0329.483] I> Rebooting : reset-coldboot
����Shutdown state requested 1
Rebooting system ...
[0000.053] W> RATCHET: MB1 binary ratchet value 4 is larger than ratchet level 2 from HW fuses.
[0000.061] I> MB1 (prd-version: 2.5.0.0-t194-41334769-d9272b5a)
[0000.066] I> Boot-mode: Coldboot
[0000.069] I> Platform: Silicon
[0000.072] I> Chip revision : A02P
[0000.075] I> Bootrom patch version : 15 (correctly patched)
[0000.080] I> ATE fuse revision : 0x200
[0000.084] I> Ram repair fuse : 0x0
[0000.087] I> Ram Code : 0x2
[0000.089] I> rst_source: 0xb, rst_level: 0x1
[0000.094] I> Boot-device: SDMMC (instance: 3)
[0000.110] I> sdmmc DDR50 mode
[0000.114] I> Boot chain mechanism: A/B
[0000.117] I> Current Boot-Chain Slot: 0
[0000.121] I> BR-BCT Boot-Chain: 0, status: 0. update flag: 0
[0000.128] W> PROD_CONFIG: device prod data is empty in MB1 BCT.
[0000.133] I> Temperature = 36500
[0000.136] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.141] W> Skipping boost for clk: BPMP_APB
[0000.145] W> Skipping boost for clk: AXI_CBB
[0000.149] W> Skipping boost for clk: AON_CPU_NIC
[0000.153] W> Skipping boost for clk: CAN1
[0000.157] W> Skipping boost for clk: CAN2
[0000.161] I> Boot-device: SDMMC (instance: 3)
[0000.170] I> Sdmmc: HS400 mode enabled
[0000.174] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.181] W> Thermal config not found in BCT
[0000.189] W> MEMIO rail config not found in BCT
[0000.211] I> sdmmc bdev is already initialized
[0000.256] W> Platform config not found in BCT
[0000.290] I> MB1 done
����main enter
HW Function test
Start Scheduler.
in late init
[0000.299] I> Welcome to MB2(TBoot-BPMP) (version: default.t194-mobile-78ae5a2a)
[0000.300] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.300] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.301] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.307] W> device prod register failed
[0000.311] I> gpio framework initialized
[0000.314] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0000.322] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0000.330] I> No valid sdcard_params in mb1_bct
[0000.334] I> Boot_device: SDMMC_BOOT instance: 3
[0000.338] I> sdmmc-3 params source = boot args
[0000.347] I> sdmmc-3 params source = boot args
[0000.348] I> sdmmc bdev is already initialized
[0000.381] I> Found 20 partitions in SDMMC_BOOT (instance 3)
[0000.397] I> Found 44 partitions in SDMMC_USER (instance 3)
[0000.398] I> Active Boot chain : 0
[0000.456] I> Relocating BR-BCT
[0000.457] > DEVICE_PROD: device prod is not initialized.
[0000.482] E> I2C: slave not found in slaves.
[0000.483] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0000.484] E> I2C_DEV: Failed to send register address 0x00000000.
[0000.485] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
[0000.486] E> eeprom: Failed to read I2C slave device
[0000.489] I> Failed to read CVB eeprom data @ AE
[0000.493] I> Retrying CVB eeprom read @ AC ...
[0000.568] I> Relocating OP-TEE dtb from: 0x6bfff240 to 0x70050000, size: 1008
[0000.568] I> [0] START: 0x80000000, SIZE: 0x2f000000
[0000.569] I> [1] START: 0xaf010000, SIZE: 0x18bf0000
[0000.569] I> [2] START: 0xc7d00000, SIZE: 0xc0000
[0000.570] I> [3] START: 0xca000000, SIZE: 0x800000
[0000.570] I> dram_block larger than 80000000
[0000.573] I> [4] START: 0x100000000, SIZE: 0x780000000
[0000.584] I> Setting NS memory ranges to OP-TEE dtb finished.
[0000.598] I> found decompressor handler: lz4
[0001.093] I> EKB detected (length: 0x410) @ VA:0x526ff400
[0001.095] I> Setting EKB blob info to OPTEE dtb finished.
I/TC:
��bpmp: init
fuse initialized
hwwdt initialized
ec initialized
vmon initialized
adc initialized
fmon initialized
mc initialized
reset initialized
nvhs initialized
clk initialized
io_dpd initialized
thermal initialized
i2c initialized
vrmon initialized
��I/TC: OP-TEE version: 3.19 (gcc ver��avfs_clk_platform initialized
��sion 9.3.0 ��soctherm initialized
��(B��aotag initialized
��ui��powergate initialized
��ldroot 2020.08)) #2 Tue Jan 24 23:20:42 UTC 2023 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/lates��dvs initialized
��t/��pm initialized
��a��suspend initialized
��rch��pg_late initialized
��it��pg_mrq_init initialized
strap initialized
��e��nvl initialized
��cture/port��emc initialized
emc_mrq initialized
��ing_guidelines.html
��clk_dt initialized
tj_init initialized
uphy_dt initialized
uphy initialized
ec_late initialized
ec_mrq initialized
clk_mrq initialized
i2c_mrq initialized
tag_mrq initialized
mrq initialized
pm_post initialized
dbells initialized
dmce initialized
cvc initialized
rm initialized
mc_reg initialized
pg_post initialized
profile initialized
bpmp: init complete
[0001.746] I> Welcome to NVDisp-Init
[0001.746] I> NVDisp-Init version: t194-709c0123
[0001.746] I> CPU-BL Params @ 0xca020000
[0001.747] I> 0) Base:0x00000000 Size:0x00000000
[0001.747] I> 1) Base:0xc8300000 Size:0x00100000
[0001.747] I> 2) Base:0xc9800000 Size:0x00200000
[0001.748] I> 3) Base:0xc8600000 Size:0x00200000
[0001.750] I> 4) Base:0xc8200000 Size:0x00100000
[0001.755] I> 5) Base:0xc8100000 Size:0x00100000
[0001.759] I> 6) Base:0xc9400000 Size:0x00400000
[0001.764] I> 7) Base:0xc9000000 Size:0x00400000
[0001.768] I> 8) Base:0xc8000000 Size:0x00100000
[0001.772] I> 9) Base:0xc7f00000 Size:0x00100000
[0001.777] I> 10) Base:0xca800000 Size:0x00800000
[0001.781] I> 11) Base:0x40000000 Size:0x00040000
[0001.786] I> 12) Base:0xc7e00000 Size:0x00100000
[0001.790] I> 13) Base:0x40046000 Size:0x00002000
[0001.795] I> 14) Base:0x40048000 Size:0x00002000
[0001.799] I> 15) Base:0xaf000000 Size:0x00004000
[0001.804] I> 16) Base:0x4004a000 Size:0x00002000
[0001.808] I> 17) Base:0xc7c00000 Size:0x00100000
[0001.813] I> 18) Base:0x4004c000 Size:0x00002000
[0001.817] I> 19) Base:0xc9a00000 Size:0x00600000
[0001.822] I> 20) Base:0x4004e000 Size:0x00002000
[0001.826] I> 21) Base:0xc7dc0000 Size:0x0000c000
[0001.830] I> 22) Base:0x00000000 Size:0x00000000
[0001.835] I> 23) Base:0xc7de0000 Size:0x00020000
[0001.839] I> 24) Base:0xcc000000 Size:0x02000000
[0001.844] I> 25) Base:0x40050000 Size:0x00002000
[0001.848] I> 26) Base:0x40040000 Size:0x00006000
[0001.853] I> 27) Base:0xc8c00000 Size:0x00400000
[0001.857] I> 28) Base:0xc8400000 Size:0x00200000
[0001.862] I> 29) Base:0xc8800000 Size:0x00400000
[0001.866] I> 30) Base:0xc7dd0000 Size:0x00010000
[0001.871] I> 31) Base:0x00000000 Size:0x00000000
[0001.875] I> 32) Base:0xf8000000 Size:0x08000000
[0001.880] I> 33) Base:0xce000000 Size:0x2a000000
[0001.884] I> 34) Base:0xcb000000 Size:0x01000000
[0001.888] I> 35) Base:0xae000000 Size:0x01000000
[0001.893] I> 36) Base:0xa0000000 Size:0x0e000000
[0001.897] I> 37) Base:0xca000000 Size:0x00800000
[0001.902] I> 38) Base:0x80000000 Size:0x20000000
[0001.906] I> 39) Base:0xb0000000 Size:0x08000000
[0001.911] I> 40) Base:0x00000000 Size:0x00000000
[0001.915] I> 41) Base:0x00000000 Size:0x00000000
[0001.920] I> 42) Base:0x00000000 Size:0x00000000
[0001.924] I> 43) Base:0x00000000 Size:0x00000000
[0001.929] I> 44) Base:0x00000000 Size:0x00000000
[0001.933] I> 45) Base:0x00000000 Size:0x00000000
[0001.938] GIC-SPI Target CPU: 0
[0001.941] Interrupts Init done
[0001.943] calling constructors
[0001.946] initializing heap
[0001.949] I> Heap: [0xa0960000 ... 0xadf00000]
[0001.953] initializing threads
[0001.956] initializing timers
[0001.959] creating bootstrap completion thread
[0001.963] top of bootstrap2()
[0001.966] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.971] initializing platform
[0001.974] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.979] W> device prod register failed
[0001.983] I> Bl_dtb @0xadf00000
[0001.986] I> gpio framework initialized
[0001.998] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0002.004] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0002.009] I> fixed regulator driver initialized
[0002.030] I> register 'maxim' power off handle
[0002.033] I> virtual i2c enabled
[0002.033] I> registered 'maxim,max20024' pmic
[0002.033] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0002.034] I> Boot-device: eMMC
[0002.034] I> Boot_device: SDMMC_BOOT instance: 3
[0002.036] I> sdmmc-3 params source = boot args
[0002.039] W> No board IDs available
[0002.042] E> Failed to get board id info!
[0002.046] I> sdmmc bdev is already initialized
[0002.050] I> sdmmc-3 params source = boot args
[0002.057] I> Found 20 partitions in SDMMC_BOOT (instance 3)
[0002.062] I> Found 44 partitions in SDMMC_USER (instance 3)
[0002.085] I> enabling 'vdd-hdmi-5v0' regulator
[0002.092] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.092] I> hdmi cable connected
[0002.098] W> set volts not configured for 'vdd-1v0'
[0002.104] W> set volts not configured for 'vdd-1v8-hs'
[0002.104] I> retrieved tmds range from prod_list_hdmi_soc
[0002.106] E> cannot find any other nvdisp nodes
[0002.122] I> edid read success
[0002.134] I> edid read success
[0002.135] I> width = 640, height = 480, frequency = 25174825
[0002.136] I> width = 640, height = 480, frequency = 25174825
[0002.136] I> width = 1024, height = 768, frequency = 65000000
[0002.140] I> width = 1024, height = 768, frequency = 65000000
[0002.146] I> width = 1024, height = 768, frequency = 65000000
[0002.151] I> width = 1920, height = 1080, frequency = 148500000
[0002.157] I> width = 1920, height = 1080, frequency = 335750000
[0002.163] I> width = 1920, height = 1080, frequency = 148351648
[0002.169] I> width = 1920, height = 1080, frequency = 148351648
[0002.174] I> width = 1280, height = 720, frequency = 74175824
[0002.180] I> width = 1280, height = 720, frequency = 74175824
[0002.185] I> width = 720, height = 480, frequency = 26973026
[0002.191] I> width = 720, height = 576, frequency = 26973026
[0002.197] I> width = 720, height = 480, frequency = 26973026
[0002.202] I> width = 720, height = 576, frequency = 26973026
[0002.208] I> width = 640, height = 480, frequency = 25174825
[0002.213] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.224] I> hdmi_enable, starting HDMI initialisation
[0002.229] I> hdmi_enable, HDMI initialisation complete
[0002.238] initializing target
[0002.239] calling apps_init()
[0002.239] starting app kernel_boot_app
[0002.240] I> Kernel type = Normal
Jetson UEFI firmware (version 2.1-32413640 built on 2023-01-24T23:12:27+00:00)
** WARNING: Test Key is used. **
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
��I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
��[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x4e0f0040]
[ 0.000000] Linux version 5.10.104-tegra (buildbrain@mobile-u64-6348-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld3[ 0.000000] Machine model: Jetson-AGX
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x859928e98 SMBIOS=0xc7db0000 SMBIOS 3.0=0x858490000 MEMATTR=0x858fe1018 ESRT=0x857f90e98 RNG=0x87c1afd98 MEMRESERVE=0x858fe2f
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x0000000857f90e98 to 0x0000000857f90ed0.
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000087fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000a096afff]
[ 0.000000] node 0: [mem 0x00000000a096b000-0x00000000a096cfff]
[ 0.000000] node 0: [mem 0x00000000a096e000-0x00000000aeffffff]
[ 0.000000] node 0: [mem 0x00000000af010000-0x00000000c7bfffff]
[ 0.000000] node 0: [mem 0x00000000c7d00000-0x00000000c7d9ffff]
[ 0.000000] node 0: [mem 0x00000000c7da0000-0x00000000c7dbffff]
[ 0.000000] node 0: [mem 0x00000000ca000000-0x00000000ca5fffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000085754dfff]
[ 0.000000] node 0: [mem 0x000000085754e000-0x0000000857f8ffff]
[ 0.000000] node 0: [mem 0x0000000857f90000-0x000000085847ffff]
[ 0.000000] node 0: [mem 0x0000000858480000-0x000000085849ffff]
[ 0.000000] node 0: [mem 0x00000008584a0000-0x0000000858bfffff]
[ 0.000000] node 0: [mem 0x0000000858c00000-0x0000000858ddffff]
[ 0.000000] node 0: [mem 0x0000000858de0000-0x0000000858e4ffff]
[ 0.000000] node 0: [mem 0x0000000858e50000-0x0000000858f0ffff]
[ 0.000000] node 0: [mem 0x0000000858f10000-0x0000000858f1ffff]
[ 0.000000] node 0: [mem 0x0000000858f20000-0x0000000858f4ffff]
[ 0.000000] node 0: [mem 0x0000000858f50000-0x0000000858f6ffff]
[ 0.000000] node 0: [mem 0x0000000858f70000-0x0000000858f9ffff]
[ 0.000000] node 0: [mem 0x0000000858fa0000-0x0000000858feffff]
[ 0.000000] node 0: [mem 0x0000000858ff0000-0x00000008590affff]
[ 0.000000] node 0: [mem 0x00000008590b0000-0x00000008590bffff]
[ 0.000000] node 0: [mem 0x00000008590c0000-0x000000085910ffff]
[ 0.000000] node 0: [mem 0x0000000859110000-0x000000085912ffff]
[ 0.000000] node 0: [mem 0x0000000859130000-0x000000085935ffff]
[ 0.000000] node 0: [mem 0x0000000859360000-0x000000085937ffff]
[ 0.000000] node 0: [mem 0x0000000859380000-0x000000085941ffff]
[ 0.000000] node 0: [mem 0x0000000859420000-0x00000008598bffff]
[ 0.000000] node 0: [mem 0x00000008598c0000-0x00000008598dffff]
[ 0.000000] node 0: [mem 0x00000008598e0000-0x00000008598effff]
[ 0.000000] node 0: [mem 0x00000008598f0000-0x000000085991ffff]
[ 0.000000] node 0: [mem 0x0000000859920000-0x0000000859b3ffff]
[ 0.000000] node 0: [mem 0x0000000859b40000-0x0000000859bdffff]
[ 0.000000] node 0: [mem 0x0000000859be0000-0x0000000859c8ffff]
[ 0.000000] node 0: [mem 0x0000000859c90000-0x0000000859d2ffff]
[ 0.000000] node 0: [mem 0x0000000859d30000-0x0000000859dbffff]
[ 0.000000] node 0: [mem 0x0000000859dc0000-0x0000000859e5ffff]
[ 0.000000] node 0: [mem 0x0000000859e60000-0x000000085a82ffff]
[ 0.000000] node 0: [mem 0x000000085a830000-0x000000085aa0ffff]
[ 0.000000] node 0: [mem 0x000000085aa10000-0x000000087c19ffff]
[ 0.000000] node 0: [mem 0x000000087c1a0000-0x000000087c1effff]
[ 0.000000] node 0: [mem 0x000000087c1f0000-0x000000087fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000087fffffff]
[ 0.000000] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c3c00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90200 r8192 d32680 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v2
[ 0.000000] CPU features: detected: NVIDIA Carmel CNP erratum
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 8032420
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 n
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000b3c00000-0x00000000c3c00000] (256MB)
[ 0.000000] Memory: 31669136K/32639676K available (18432K kernel code, 3168K rwdata, 7164K rodata, 3968K init, 1110K bss, 905004K reserved, 65536K cma)[ 0.000000] random: get_random_u64 called from __kmem_cache_create+0x38/0x420 with crng_init=0
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000600] Console: colour dummy device 80x25
[ 0.001948] printk: console [tty0] enabled
[ 0.002023] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.002068] pid_max: default: 32768 minimum: 301
[ 0.002228] LSM: Security Framework initializing
[ 0.002290] Yama: becoming mindful.
[ 0.002335] SELinux: Initializing.
[ 0.002496] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.002576] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.005833] rcu: Hierarchical SRCU implementation.
[ 0.006119] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.006841] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/galei[ 0.006911] DTB Build time: Jan 24 2023 15:26:08
[ 0.009708] Tegra Revision: A02 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.009963] Remapping and enabling EFI services.
[ 0.012411] smp: Bringing up secondary CPUs ...
[ 0.043658] Detected PIPT I-cache on CPU1
[ 0.043729] CPU1: Booted secondary processor 0x0000000001 [0x4e0f0040]
[ 0.075202] Detected PIPT I-cache on CPU2
[ 0.075364] CPU2: Booted secondary processor 0x0000000100 [0x4e0f0040]
[ 0.104955] Detected PIPT I-cache on CPU3
[ 0.105102] CPU3: Booted secondary processor 0x0000000101 [0x4e0f0040]
[ 0.134566] Detected PIPT I-cache on CPU4
[ 0.134745] CPU4: Booted secondary processor 0x0000000200 [0x4e0f0040]
[ 0.164240] Detected PIPT I-cache on CPU5
[ 0.164401] CPU5: Booted secondary processor 0x0000000201 [0x4e0f0040]
[ 0.194089] Detected PIPT I-cache on CPU6
[ 0.194270] CPU6: Booted secondary processor 0x0000000300 [0x4e0f0040]
[ 0.223786] Detected PIPT I-cache on CPU7
[ 0.224023] CPU7: Booted secondary processor 0x0000000301 [0x4e0f0040]
[ 0.224492] smp: Brought up 1 node, 8 CPUs
[ 0.224939] SMP: Total of 8 processors activated.
[ 0.225020] CPU features: detected: Privileged Access Never
[ 0.225050] CPU features: detected: LSE atomic instructions
[ 0.225070] CPU features: detected: User Access Override
[ 0.225090] CPU features: detected: 32-bit EL0 Support
[ 0.225109] CPU features: detected: RAS Extension Support
[ 0.225128] CPU features: detected: CRC32 instructions
[ 0.225146] CPU features: detected: 32-bit EL1 Support
[ 0.287260] CPU: All CPU(s) started at EL2
[ 0.298213] devtmpfs: initialized
[ 0.348275] Registered cp15_barrier emulation handler
[ 0.348408] Registered setend emulation handler
[ 0.348430] KASLR enabled
[ 0.348677] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.348710] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.350015] pinctrl core: initialized pinctrl subsystem
[ 0.351000] SMBIOS 3.0.0 present.
[ 0.351028] DMI: Unknown Jetson-AGX/Jetson-AGX, BIOS 2.1-32413640 01/24/2023
[ 0.351621] NET: Registered protocol family 16
[ 0.354157] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.355745] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.357306] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.357376] audit: initializing netlink subsys (disabled)
[ 0.357687] audit: type=2000 audit(0.352:1): state=initialized audit_enabled=0 res=1
[ 0.358116] thermal_sys: Registered thermal governor 'step_wise'
[ 0.358122] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.358139] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.360924] cpuidle: using governor menu
[ 0.361290] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.361897] ASID allocator initialised with 32768 entries
[ 0.362108] Serial: AMBA PL011 UART driver
[ 0.365338] Tegra reboot handler registered.
[ 0.433156] mc: mapped MMIO address: 0xffff800010ee0000 -> 0x2c10000
[ 0.433210] mc: mapped MMIO address: 0xffff800010f00000 -> 0x2c20000
[ 0.433241] mc: mapped MMIO address: 0xffff800010f20000 -> 0x2c30000
[ 0.433277] mc: mapped MMIO address: 0xffff800010f40000 -> 0x2c40000
[ 0.433304] mc: mapped MMIO address: 0xffff800010f60000 -> 0x2c50000
[ 0.433331] mc: mapped MMIO address: 0xffff800010f80000 -> 0x2b80000
[ 0.433359] mc: mapped MMIO address: 0xffff800010fa0000 -> 0x2b90000
[ 0.433385] mc: mapped MMIO address: 0xffff800010fc0000 -> 0x2ba0000
[ 0.433414] mc: mapped MMIO address: 0xffff800010fe0000 -> 0x2bb0000
[ 0.433442] mc: mapped MMIO address: 0xffff800011000000 -> 0x1700000
[ 0.433467] mc: mapped MMIO address: 0xffff800011020000 -> 0x1710000
[ 0.433493] mc: mapped MMIO address: 0xffff800011040000 -> 0x1720000
[ 0.433519] mc: mapped MMIO address: 0xffff800011060000 -> 0x1730000
[ 0.433544] mc: mapped MMIO address: 0xffff800011080000 -> 0x1740000
[ 0.433573] mc: mapped MMIO address: 0xffff8000110a0000 -> 0x1750000
[ 0.433598] mc: mapped MMIO address: 0xffff8000110c0000 -> 0x1760000
[ 0.433624] mc: mapped MMIO address: 0xffff8000110e0000 -> 0x1770000
[ 0.433705] mc-err: mcerr ops are set to t19x
[ 0.444533] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.444563] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.444578] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.444612] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.450482] ACPI: Interpreter disabled.
[ 0.451152] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.452876] iommu: Default domain type: Translated
[ 0.452947] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.453312] SCSI subsystem initialized
[ 0.453462] usbcore: registered new interface driver usbfs
[ 0.453499] usbcore: registered new interface driver hub
[ 0.453538] usbcore: registered new device driver usb
[ 0.453895] mc: Linux media interface: v0.10
[ 0.453924] videodev: Linux video capture interface: v2.00
[ 0.454201] pps_core: LinuxPPS API ver. 1 registered
[ 0.454214] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.454241] PTP clock support registered
[ 0.454421] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.454677] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.454724] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.455265] Registered efivars operations
[ 0.462785] FPGA manager framework
[ 0.462905] Advanced Linux Sound Architecture Driver Initialized.
[ 0.463412] Bluetooth: Core ver 2.22
[ 0.463455] NET: Registered protocol family 31
[ 0.463467] Bluetooth: HCI device and connection manager initialized
[ 0.463484] Bluetooth: HCI socket layer initialized
[ 0.463499] Bluetooth: L2CAP socket layer initialized
[ 0.463520] Bluetooth: SCO socket layer initialized
[ 0.464876] camchar: rtcpu character device driver loaded
[ 0.465647] clocksource: Switched to clocksource arch_sys_counter
[ 0.712663] VFS: Disk quotas dquot_6.6.0
[ 0.712746] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.712995] pnp: PnP ACPI: disabled
[ 0.725331] la/ptsa driver initialized.
[ 0.725470] NET: Registered protocol family 2
[ 0.725731] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.733943] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.734163] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.734937] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.735305] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.735445] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.735707] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.736095] NET: Registered protocol family 1
[ 0.737118] RPC: Registered named UNIX socket transport module.
[ 0.737157] RPC: Registered udp transport module.
[ 0.737178] RPC: Registered tcp transport module.
[ 0.737196] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.737225] PCI: CLS 0 bytes, default 64
[ 0.737592] Trying to unpack rootfs image as initramfs...
[ 1.012050] Freeing initrd memory: 8208K
[ 1.018946] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.019488] kvm [1]: IPA Size Limit: 40 bits
[ 1.020338] kvm [1]: vgic interrupt IRQ9
[ 1.021244] kvm [1]: VHE mode initialized successfully
[ 1.023190] Initialise system trusted keyrings
[ 1.023633] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[ 1.030709] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.031575] NFS: Registering the id_resolver key type
[ 1.031619] Key type id_resolver registered
[ 1.031637] Key type id_legacy registered
[ 1.031732] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.031772] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.031818] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.042433] NET: Registered protocol family 38
[ 1.042464] Key type asymmetric registered
[ 1.042483] Asymmetric key parser 'x509' registered
[ 1.042535] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.042838] io scheduler mq-deadline registered
[ 1.042862] io scheduler kyber registered
[ 1.053003] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.053094] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.053178] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.053257] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.059809] scrncapt: init (heads:4 wins:6 planes:4)
[ 1.060142] tegradccommon 15200000.display-hub: Nvhost Channel map failed
[ 1.061247] EINJ: ACPI disabled.
[ 1.064910] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 1.064944] tegra-pmc: ### PMC reset source: MAINSWRST
[ 1.064989] tegra-pmc: ### PMC reset level: L1
[ 1.065007] tegra-pmc: ### PMC reset status reg: 0x2d
[ 1.065060] tegra-pmc: PMC Prod config success
[ 1.071096] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.076828] random: fast init done
[ 1.077013] printk: console [ttyTCU0] enabled
[ 2.586196] arm-smmu 10000000.iommu: probing hardware configuration...
[ 2.590759] arm-smmu 10000000.iommu: SMMUv2 with:
[ 2.595308] arm-smmu 10000000.iommu: stage 1 translation
[ 2.600599] arm-smmu 10000000.iommu: stage 2 translation
[ 2.606341] arm-smmu 10000000.iommu: nested translation
[ 2.611417] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 2.618608] arm-smmu 10000000.iommu: 64 context banks (0 stage-2 only)
[ 2.630743] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 2.631683] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.638526] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.646032] arm-smmu 12000000.iommu: probing hardware configuration...
[ 2.651309] arm-smmu 12000000.iommu: SMMUv2 with:
[ 2.656290] arm-smmu 12000000.iommu: stage 1 translation
[ 2.661543] arm-smmu 12000000.iommu: stage 2 translation
[ 2.667222] arm-smmu 12000000.iommu: nested translation
[ 2.672393] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 2.679574] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 2.691638] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 2.692671] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.699521] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.706631] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 2.717866] tegra_profiler: version: 1.150, samples/io: 50/29
[ 2.719630] tegra_profiler: auth: init
[ 2.724465] THERMAL EST: found 3 subdevs
[ 2.727628] THERMAL EST num_resources: 0
[ 2.731207] [THERMAL EST subdev 0]
[ 2.734789] [THERMAL EST subdev 1]
[ 2.737933] [THERMAL EST subdev 2]
[ 2.741415] THERMAL EST: Found 2 profiles, default profile is quiet
[ 2.747952] THERMAL EST: thz register success.
[ 2.752140] THERMAL EST: end of probe, return err: 0
[ 2.757338] nvsciipc: loaded module
[ 2.764434] tun: Universal TUN/TAP device driver, 1.6
[ 2.766787] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 2.772947] hns3: Copyright (c) 2017 Huawei Corporation.
[ 2.778758] e1000e: Intel(R) PRO/1000 Network Driver
[ 2.783430] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.789788] igb: Intel(R) Gigabit Ethernet Network Driver
[ 2.795064] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.801275] PPP generic driver version 2.4.2
[ 2.805538] PPP BSD Compression module registered
[ 2.809777] PPP Deflate Compression module registered
[ 2.815026] PPP MPPE Compression module registered
[ 2.820302] usbcore: registered new interface driver r8152
[ 2.825549] usbcore: registered new interface driver asix
[ 2.831149] usbcore: registered new interface driver ax88179_178a
[ 2.837279] usbcore: registered new interface driver cdc_ether
[ 2.842957] usbcore: registered new interface driver net1080
[ 2.848556] usbcore: registered new interface driver cdc_subset
[ 2.854849] usbcore: registered new interface driver zaurus
[ 2.860552] usbcore: registered new interface driver cdc_ncm
[ 2.866226] usbcore: registered new interface driver aqc111
[ 2.871899] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.877686] ohci-pci: OHCI PCI platform driver
[ 2.882241] ohci-platform: OHCI generic platform driver
[ 2.888091] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 2.894180] usbcore: registered new interface driver uas
[ 2.898289] usbcore: registered new interface driver usb-storage
[ 2.904437] tegra-xudc 3550000.xudc: Adding to iommu group 1
[ 2.910443] mousedev: PS/2 mouse device common for all mice
[ 2.915460] usbcore: registered new interface driver xpad
[ 2.923691] tegra_rtc c2a0000.rtc: registered as rtc1
[ 2.926443] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:24 UTC (24)
[ 2.934236] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.940744] i2c /dev entries driver
[ 2.943890] tegra-i2c 3160000.i2c: Adding to iommu group 2
[ 2.949765] tegra-i2c c240000.i2c: Adding to iommu group 2
[ 2.955349] tegra-i2c 3180000.i2c: Adding to iommu group 2
[ 2.960739] tegra-i2c 3190000.i2c: Adding to iommu group 2
[ 2.965953] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[ 2.971450] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[ 2.976939] tegra-i2c c250000.i2c: Adding to iommu group 2
[ 2.988090] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 2.990296] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 2.998244] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 3.008325] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[ 3.014336] device-mapper: uevent: version 1.0.3
[ 3.018600] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 3.029166] cpuidle: Initializing cpuidle driver
[ 3.032877] sdhci: Secure Digital Host Controller Interface driver
[ 3.037975] sdhci: Copyright(c) Pierre Ossman
[ 3.042156] Synopsys Designware Multimedia Card Interface Driver
[ 3.048568] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.054574] sdhci-tegra 3460000.sdhci: Adding to iommu group 3
[ 3.054977] sdhci-tegra 3400000.sdhci: Adding to iommu group 4
[ 3.055388] SMCCC: SOC_ID: ID = jep106:036b:0019 Revision = 0x00000102
[ 3.060452] tegra-bpmp bpmp: firmware: 128431eec76692047e1ac1ebc0392266
[ 3.095069] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[ 3.104268] vdd-1v0: supplied by regulator-dummy
[ 3.109822] vdd-1v8-hs: supplied by regulator-dummy
[ 3.114728] vdd-1v8-ls: supplied by regulator-dummy
[ 3.119547] vdd-1v8-ao: supplied by regulator-dummy
[ 3.123501] vddio-ddr-1v1: supplied by regulator-dummy
[ 3.128352] vdd-rtc: supplied by regulator-dummy
[ 3.130161] spmic-ldo1: supplied by regulator-dummy
[ 3.131819] vdd-ao-3v3: supplied by regulator-dummy
[ 3.138381] vddio-emmc-3v3: supplied by regulator-dummy
[ 3.144671] spmic-ldo4: supplied by regulator-dummy
[ 3.146260] vdd-usb-3v3: supplied by regulator-dummy
[ 3.152843] vddio-sdmmc1-3v3: supplied by regulator-dummy
[ 3.159423] vdd-csi-1v2: supplied by vdd-1v8-ls
[ 3.165376] spmic-ldo8: supplied by vdd-1v8-ls
[ 3.167192] gpio-510 (gpio_default): hogged as output/high
[ 3.168970] gpio-511 (gpio_default): hogged as output/high
[ 3.171616] gpiochip0: registered GPIOs 504 to 511 on max77620-gpio
[ 3.306672] max77686-rtc max77620-rtc: registered as rtc0
[ 3.307612] max77620-power max20024-power: Event recorder REG_NVERC : 0x44
[ 3.307884] max77620 4-003c: max77620 probe successful
��debugfs initialized
��[ 4.130687] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 4.131743] hid: raw HID events driver (C) Jiri Kosina
[ 4.132332] usbcore: registered new interface driver usbhid
[ 4.132464] usbhid: USB HID core driver
[ 4.134432] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 5
[ 4.135538] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
��[ 25.912306] Camera-FW on t194-rce-safe started
TCU early console enabled.
[ 25.987075] Camera-FW on t194-rce-safe ready SHA1=01b72e3c (crt 0.774 ms, total boot 75.572 ms)
��[ 4.220825] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 4.221357] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 4.222388] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 4.223011] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 4.224524] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 4.225092] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 4.225647] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 4.226936] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (54)
[ 4.227132] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 4.228662] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=01b72e3c1b59ab02ad8c842bed3160278b410129
[ 4.236216] tegra_aon c1a0000.aon: Adding to iommu group 6
[ 4.243280] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 4.247712] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 4.255505] denver_knobs_init:MTS_VERSION:55637613
[ 4.271023] t19x_cache tegra-cache: probed
[ 4.276008] optee: probing for conduit method.
[ 4.276867] optee: revision 3.19 (18d0f61b)
[ 4.278210] optee: dynamic shared memory is enabled
[ 4.279745] optee: initialized driver
[ 4.284151] nvpmodel: initialized successfully
[ 4.284705] tegra_hv: get_hvd: not initialized yet
[ 4.287483] user_ivc_mempool: hypervisor not present
[ 4.293254] usbcore: registered new interface driver snd-usb-audio
[ 4.299901] u32 classifier
[ 4.300841] input device check on
[ 4.304553] Actions configured
[ 4.308508] Initializing XFRM netlink socket
[ 4.313303] NET: Registered protocol family 10
[ 4.320162] Segment Routing with IPv6
[ 4.320693] NET: Registered protocol family 17
[ 4.324742] NET: Registered protocol family 15
[ 4.329454] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.343171] Bluetooth: RFCOMM socket layer initialized
[ 4.347398] Bluetooth: RFCOMM ver 1.11
[ 4.351545] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.357139] Bluetooth: HIDP socket layer initialized
[ 4.363287] 9pnet: Installing 9P2000 support
[ 4.366848] Key type dns_resolver registered
[ 4.371937] registered taskstats version 1
[ 4.375012] Loading compiled-in X.509 certificates
[ 4.389119] Loaded X.509 cert 'Build time autogenerated kernel key: d2e6b29ce3ba3f3d31103e414d71889f8474be7b'
[ 4.391000] tegra194-pcie 14180000.pcie: Adding to iommu group 7
[ 4.401341] tegra194-pcie 14180000.pcie: host bridge /pcie@14180000 ranges:
[ 4.403265] tegra194-pcie 14180000.pcie: IO 0x0038100000..0x00381fffff -> 0x0038100000
[ 4.411526] tegra194-pcie 14180000.pcie: MEM 0x1800000000..0x1b3fffffff -> 0x1800000000
[ 4.420149] tegra194-pcie 14180000.pcie: MEM 0x1b40000000..0x1bffffffff -> 0x0040000000
[ 4.537786] tegra194-pcie 14180000.pcie: Link up
[ 4.549789] tegra194-pcie 14180000.pcie: PCI host bridge to bus 0000:00
[ 4.549992] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 4.550120] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0x38100000-0x381fffff])
[ 4.550346] pci_bus 0000:00: root bus resource [mem 0x1800000000-0x1b3fffffff pref]
[ 4.550520] pci_bus 0000:00: root bus resource [mem 0x1b40000000-0x1bffffffff] (bus address [0x40000000-0xffffffff])
[ 4.550804] pci 0000:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 4.551127] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[ 4.562762] pci 0000:01:00.0: [144d:a80a] type 00 class 0x010802
[ 4.563105] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 4.575693] pci 0000:00:00.0: BAR 14: assigned [mem 0x1b40000000-0x1b400fffff]
[ 4.575959] pci 0000:01:00.0: BAR 0: assigned [mem 0x1b40000000-0x1b40003fff 64bit]
[ 4.576261] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 4.576457] pci 0000:00:00.0: bridge window [mem 0x1b40000000-0x1b400fffff]
[ 4.576695] pci 0000:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 4.577033] pci 0000:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 4.578118] pcieport 0000:00:00.0: Adding to iommu group 7
[ 4.578866] pcieport 0000:00:00.0: PME: Signaling with IRQ 24
[ 4.579858] pcieport 0000:00:00.0: AER: enabled with IRQ 24
[ 4.585885] nvme 0000:01:00.0: Adding to iommu group 7
[ 4.591249] nvme nvme0: pci function 0000:01:00.0
[ 4.595087] nvme 0000:01:00.0: enabling device (0000 -> 0002)
[ 4.596034] tegra194-pcie 14100000.pcie: Adding to iommu group 8
[ 4.605145] nvme nvme0: Shutdown timeout set to 10 seconds
[ 4.608577] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 4.616077] nvme nvme0: 8/0/0 default/read/poll queues
[ 4.618941] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 4.627812] nvme0n1: p1
[ 4.632661] tegra194-pcie 14100000.pcie: MEM 0x1200000000..0x122fffffff -> 0x1200000000
[ 4.632678] tegra194-pcie 14100000.pcie: MEM 0x1230000000..0x123fffffff -> 0x0040000000
[ 4.757714] tegra194-pcie 14100000.pcie: Link up
[ 4.759574] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 4.759738] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 4.759858] pci_bus 0001:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x30100000-0x301fffff])
[ 4.760066] pci_bus 0001:00: root bus resource [mem 0x1200000000-0x122fffffff pref]
[ 4.760240] pci_bus 0001:00: root bus resource [mem 0x1230000000-0x123fffffff] (bus address [0x40000000-0x4fffffff])
[ 4.760406] random: crng init done
[ 4.760514] pci 0001:00:00.0: [10de:1ad2] type 01 class 0x060400
[ 4.760964] pci 0001:00:00.0: PME# supported from D0 D3hot D3cold
[ 4.772569] pci 0001:01:00.0: [1b4b:9171] type 00 class 0x010601
[ 4.772914] pci 0001:01:00.0: reg 0x10: [io 0x8000-0x8007]
[ 4.773150] pci 0001:01:00.0: reg 0x14: [io 0x8040-0x8043]
[ 4.773429] pci 0001:01:00.0: reg 0x18: [io 0x8100-0x8107]
[ 4.773712] pci 0001:01:00.0: reg 0x1c: [io 0x8140-0x8143]
[ 4.773942] pci 0001:01:00.0: reg 0x20: [io 0x800000-0x80000f]
[ 4.774187] pci 0001:01:00.0: reg 0x24: [mem 0x00900000-0x009001ff]
[ 4.774426] pci 0001:01:00.0: reg 0x30: [mem 0xd0000000-0xd000ffff pref]
[ 4.775398] pci 0001:01:00.0: PME# supported from D3hot
[ 4.800459] pci 0001:00:00.0: BAR 14: assigned [mem 0x1230000000-0x12300fffff]
[ 4.800707] pci 0001:00:00.0: BAR 13: assigned [io 0x100000-0x100fff]
[ 4.800897] pci 0001:01:00.0: BAR 6: assigned [mem 0x1230000000-0x123000ffff pref]
[ 4.801403] pci 0001:01:00.0: BAR 5: assigned [mem 0x1230010000-0x12300101ff]
[ 4.808716] pci 0001:01:00.0: BAR 4: assigned [io 0x100000-0x10000f]
[ 4.814761] pci 0001:01:00.0: BAR 0: assigned [io 0x100010-0x100017]
[ 4.821139] pci 0001:01:00.0: BAR 2: assigned [io 0x100018-0x10001f]
[ 4.827525] pci 0001:01:00.0: BAR 1: assigned [io 0x100020-0x100023]
[ 4.834026] pci 0001:01:00.0: BAR 3: assigned [io 0x100024-0x100027]
[ 4.840735] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 4.845992] pci 0001:00:00.0: bridge window [io 0x100000-0x100fff]
[ 4.852309] pci 0001:00:00.0: bridge window [mem 0x1230000000-0x12300fffff]
[ 4.859572] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 4.868242] pci 0001:01:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 4.877314] pcieport 0001:00:00.0: Adding to iommu group 8
[ 4.882983] pcieport 0001:00:00.0: PME: Signaling with IRQ 26
[ 4.888503] pcieport 0001:00:00.0: AER: enabled with IRQ 26
[ 4.894699] tegra194-pcie 14140000.pcie: Adding to iommu group 9
[ 4.901450] tegra194-pcie 14140000.pcie: host bridge /pcie@14140000 ranges:
[ 4.906830] tegra194-pcie 14140000.pcie: IO 0x0034100000..0x00341fffff -> 0x0034100000
[ 4.915382] tegra194-pcie 14140000.pcie: MEM 0x1280000000..0x12afffffff -> 0x1280000000
[ 4.923677] tegra194-pcie 14140000.pcie: MEM 0x12b0000000..0x12bfffffff -> 0x0040000000
[ 5.037674] tegra194-pcie 14140000.pcie: Link up
[ 5.039467] tegra194-pcie 14140000.pcie: PCI host bridge to bus 0003:00
[ 5.039640] pci_bus 0003:00: root bus resource [bus 00-ff]
[ 5.039770] pci_bus 0003:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x34100000-0x341fffff])
[ 5.039985] pci_bus 0003:00: root bus resource [mem 0x1280000000-0x12afffffff pref]
[ 5.040174] pci_bus 0003:00: root bus resource [mem 0x12b0000000-0x12bfffffff] (bus address [0x40000000-0x4fffffff])
[ 5.040473] pci 0003:00:00.0: [10de:1ad2] type 01 class 0x060400
[ 5.040808] pci 0003:00:00.0: PME# supported from D0 D3hot D3cold
[ 5.051913] pci 0003:01:00.0: [1ac1:089a] type 00 class 0x0000ff
[ 5.052257] pci 0003:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit pref]
[ 5.052601] pci 0003:01:00.0: reg 0x18: [mem 0x00000000-0x000fffff 64bit pref]
[ 5.064641] pci 0003:00:00.0: BAR 15: assigned [mem 0x1280000000-0x12801fffff 64bit pref]
[ 5.064912] pci 0003:01:00.0: BAR 2: assigned [mem 0x1280000000-0x12800fffff 64bit pref]
[ 5.065236] pci 0003:01:00.0: BAR 0: assigned [mem 0x1280100000-0x1280103fff 64bit pref]
[ 5.065581] pci 0003:00:00.0: PCI bridge to [bus 01-ff]
[ 5.065788] pci 0003:00:00.0: bridge window [mem 0x1280000000-0x12801fffff 64bit pref]
[ 5.066060] pci 0003:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 5.070191] pci 0003:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 5.079388] pcieport 0003:00:00.0: Adding to iommu group 9
[ 5.085038] pcieport 0003:00:00.0: PME: Signaling with IRQ 28
[ 5.090698] pcieport 0003:00:00.0: AER: enabled with IRQ 28
[ 5.097077] tegra194-pcie 141a0000.pcie: Adding to iommu group 10
[ 5.120405] host1x 13e10000.host1x: Adding to iommu group 11
[ 5.134930] host1x 13e10000.host1x: initialized
[ 5.135739] iommu_context_dev 13e10000.host1x:ctx0: Adding to iommu group 12
[ 5.136154] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 5.137206] iommu_context_dev 13e10000.host1x:ctx1: Adding to iommu group 13
[ 5.137753] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 5.146819] iommu_context_dev 13e10000.host1x:ctx2: Adding to iommu group 14
[ 5.153362] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 5.163447] iommu_context_dev 13e10000.host1x:ctx3: Adding to iommu group 15
[ 5.170333] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 5.180061] iommu_context_dev 13e10000.host1x:ctx4: Adding to iommu group 16
[ 5.187181] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 5.197210] iommu_context_dev 13e10000.host1x:ctx5: Adding to iommu group 17
[ 5.203850] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61, iommu=smmu.0x0000000012000000)
[ 5.214142] iommu_context_dev 13e10000.host1x:ctx6: Adding to iommu group 18
[ 5.220926] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62, iommu=smmu.0x0000000012000000)
[ 5.230857] iommu_context_dev 13e10000.host1x:ctx7: Adding to iommu group 19
[ 5.238064] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63, iommu=smmu.0x0000000012000000)
[ 5.247867] falcon 15340000.vic: Adding to iommu group 20
[ 5.257523] falcon 15340000.vic: initialized
[ 5.258038] falcon 15380000.nvjpg: Adding to iommu group 20
[ 5.266404] falcon 15380000.nvjpg: initialized
[ 5.267807] falcon 154c0000.nvenc: Adding to iommu group 20
[ 5.277234] falcon 154c0000.nvenc: initialized
[ 5.278042] falcon 15a80000.nvenc1: Adding to iommu group 20
[ 5.288217] falcon 15a80000.nvenc1: initialized
[ 5.288582] nvdec 15480000.nvdec: Adding to iommu group 20
[ 5.298530] nvdec 15480000.nvdec: initialized
[ 5.298907] nvdec 15140000.nvdec1: Adding to iommu group 20
[ 5.309745] nvdec 15140000.nvdec1: initialized
[ 5.310104] tsec 15500000.tsec: Adding to iommu group 21
[ 5.317476] tsec 15500000.tsec: initialized
[ 5.318239] tsec 15100000.tsecb: Adding to iommu group 22
[ 5.326236] tsec 15100000.tsecb: initialized
[ 5.329677] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 5.357183] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 5.365846] gpio-374 (wifi-enable): hogged as output/high
[ 5.366062] gpio-382 (camera-control-output-low): hogged as output/low
[ 5.366275] gpio-385 (camera-control-output-low): hogged as output/low
[ 5.366530] gpio-463 (camera-control-output-low): hogged as output/low
[ 5.366747] gpio-462 (camera-control-output-low): hogged as output/low
[ 5.372563] gpio-485 (camera-control-output-low): hogged as output/low
[ 5.379714] gpiochip1: registered GPIOs 335 to 503 on tegra194-gpio
[ 5.386473] gpiochip2: registered GPIOs 305 to 334 on tegra194-gpio-aon
[ 5.391852] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 5.398102] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 5.404178] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 5.409155] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 5.416229] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 5.422995] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=6262500, max_bw=6262500
[ 5.433707] tegra194-isp5 13e10000.host1x:isp@14800000: Adding to iommu group 23
[ 5.442922] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 5.450346] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: initialized
[ 5.456905] tegra194-vi5 15c10000.vi: Adding to iommu group 24
[ 5.462874] scare-pigeon 13e10000.host1x:vi-thi@15f00000: context isolation disabled due to no IOMMU
[ 5.471304] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 5.477809] scare-pigeon 13e10000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 5.486903] scare-pigeon 13e10000.host1x:isp-thi@14b00000: initialized
[ 5.493251] pva 16000000.pva0: Adding to iommu group 25
[ 5.515899] pva 16000000.pva0: initialized
[ 5.517578] pva 16800000.pva1: Adding to iommu group 26
[ 5.526258] pva 16800000.pva1: initialized
[ 5.527781] nvdla 15880000.nvdla0: Adding to iommu group 27
[ 5.536442] nvdla 15880000.nvdla0: initialized
[ 5.537253] nvdla 158c0000.nvdla1: Adding to iommu group 28
[ 5.543816] nvdla 158c0000.nvdla1: initialized
[ 5.547902] tegra-slvs-ec 15ac0000.slvs-ec: context isolation disabled due to no IOMMU
[ 5.548359] tegra-slvs-ec 15ac0000.slvs-ec: initialized
[ 5.548646] tegra-slvs-ec 15ac0000.slvs-ec: No streams defined - setting to zero
[ 5.553030] tegra-slvs-ec 15ac0000.slvs-ec: slvs has 0 available streams
[ 5.559590] tegra-slvs-ec 15ac0000.slvs-ec: probed
[ 5.566543] tegradccommon 15200000.display-hub: host1x channel mapped
[ 5.566847] tegradc 15200000.display: Adding to iommu group 29
[ 5.567197] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=71
[ 5.567208] tegra_cec 3960000.tegra_cec: Unpowergated DISP
[ 5.567273] tegradc 15210000.display: Adding to iommu group 29
[ 5.571064] tegradccommon 15200000.display-hub: dc_common syncpt # 1 allocated
[ 5.571084] tegradc 15220000.display: Adding to iommu group 29
[ 5.571108] tegradccommon 15200000.display-hub: dma mapping done
[ 5.571163] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 5.571611] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 5.571838] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 5.571845] tegra_cec 3960000.tegra_cec: probed
[ 5.572257] tegra-gpcdma 2600000.dma: Adding to iommu group 2
[ 5.577994] tegradc 15200000.display: disp0 connected to head0->sor2
[ 5.578711] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 5.578927] kfuse 3830000.kfuse: initialized
[ 5.579262] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 5.579457] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 5.579748] serial-tegra 3100000.serial: Adding to iommu group 2
[ 5.590570] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 35, base_baud = 0) is a TEGRA_UART
[ 5.596126] generic_infoframe_type: 0x87
[ 5.604372] serial-tegra 3110000.serial: Adding to iommu group 2
[ 5.609393] tegradc 15200000.display: DT parsed successfully
[ 5.627449] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 36, base_baud = 0) is a TEGRA_UART
[ 5.632752] tegradc 15200000.display: Display dc.00000000fb731898 registered with id=0
[ 5.634326] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 5.638382] serial-tegra 3140000.serial: Adding to iommu group 2
[ 5.643231] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
[ 5.643241] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
[ 5.660802] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 37, base_baud = 0) is a TEGRA_UART
[ 5.667443] tegradc 15200000.display: vblank syncpt # 8 for dc 0
[ 5.766518] tegradc 15200000.display: vpulse3 syncpt # 9 for dc 0
[ 5.772608] tegradc 15200000.display: dc_hdmi_hotplug_init: couldn't get regulator vdd_hdmi_5v0, -517
[ 5.781755] tegradc 15200000.display: dc_probe: failed hotplug init, -517
[ 5.790444] tegradc 15220000.display: disp0 connected to head2->sor1
[ 5.795039] tegradc 15220000.display: parse_dp_settings: No dp-lt-settings node
[ 5.800086] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[ 5.802186] tegradc 15220000.display: DT parsed successfully
[ 5.813507] tegradc 15220000.display: dc.2 probe not in device tree order, deferring
[ 5.818874] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2260000 KHz, changing to: 2265600 KHz
[ 5.832656] tegra194-cpufreq ccplex: probed with BWMGR
[ 5.838962] sdhci-tegra 3460000.sdhci: BWMGR client registration for eMC Successful
[ 5.839868] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 5.839931] sdhci-tegra 3400000.sdhci: BWMGR client registration for eMC Successful
[ 5.848957] irq: IRQ284: trimming hierarchy from :interrupt-controller@3881000
[ 5.850318] reg-fixed-voltage fixed-regulators:regulator@106: nonexclusive access to GPIO for fixed-regulators:regulator@106
[ 5.857964] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 284
[ 5.865811] vdd-5v-sata: supplied by vdd-ac-bat
[ 5.876701] mmc0: CQHCI version 5.10
[ 5.887045] tegra194-isp5 13e10000.host1x:isp@14800000: initialized
[ 5.903816] tegra194-vi5 15c10000.vi: initialized
[ 5.904884] tegradc 15210000.display: disp0 connected to head1->sor
[ 5.907762] tegradc 15210000.display: parse_dp_settings: No dp-lt-settings node
[ 5.915274] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[ 5.922880] tegradc 15210000.display: DT parsed successfully
[ 5.928135] tegradc 15210000.display: dc.1 probe not in device tree order, deferring
[ 5.929271] tegra-xusb 3610000.xhci: Firmware timestamp: 2022-03-16 11:07:43 UTC, Version: 60.13 release
[ 5.937262] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[ 5.945870] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 5.945889] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 5.966928] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x0000000000050810
[ 5.976009] tegra-xusb 3610000.xhci: irq 201, io mem 0x03610000
[ 5.982288] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 5.990161] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.997674] usb usb1: Product: xHCI Host Controller
[ 6.002398] usb usb1: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 6.008866] usb usb1: SerialNumber: 3610000.xhci
[ 6.013487] hub 1-0:1.0: USB hub found
[ 6.017153] hub 1-0:1.0: 4 ports detected
[ 6.021577] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 6.026987] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 6.034340] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 6.042145] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 6.050179] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.057435] usb usb2: Product: xHCI Host Controller
[ 6.062159] usb usb2: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 6.068629] usb usb2: SerialNumber: 3610000.xhci
[ 6.073531] hub 2-0:1.0: USB hub found
[ 6.075588] mmc0: Command Queue Engine enabled
[ 6.077078] hub 2-0:1.0: 4 ports detected
[ 6.081160] mmc0: periodic cache flush enabled
[ 6.088658] tegradc 15200000.display: disp0 connected to head0->sor2
[ 6.089726] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 6.094021] mmcblk0: mmc0:0001 HBG4a2 29.1 GiB
[ 6.096024] generic_infoframe_type: 0x87
[ 6.102644] mmcblk0rpmb: mmc0:0001 HBG4a2 partition 3 4.00 MiB, chardev (510:0)
[ 6.107578] tegradc 15200000.display: DT parsed successfully
[ 6.122627] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33 p34 p4[ 6.124055] tegradc 15200000.display: Display dc.0000000009a8519e registered with id=0
[ 6.149545] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 6.157195] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
[ 6.165670] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
[ 6.173525] tegradc 15200000.display: vblank syncpt # 11 for dc 0
[ 6.179510] tegradc 15200000.display: vpulse3 syncpt # 12 for dc 0
[ 6.186122] tegradc 15200000.display: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 6.198027] tegradc 15200000.display: hdmi: invalid prod list prod_list_hdmi_board
[ 6.202051] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 6.204356] tegradc 15200000.display: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 6.211554] tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff -> 0x003a100000
[ 6.220802] tegradc 15200000.display: probed
[ 6.227455] tegra194-pcie 141a0000.pcie: MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[ 6.227464] tegra194-pcie 141a0000.pcie: MEM 0x1f40000000..0x1fffffffff -> 0x0040000000
[ 6.273685] Console: switching to colour frame buffer device 240x67
[ 6.273954] tegradc 15200000.display: fb registered
[ 6.274138] irq: IRQ285: trimming hierarchy from :pmc@c360000
[ 6.275224] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 6.275607] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 6.337734] tegradc 15200000.display: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_111m_223m
[ 6.339019] tegradc 15200000.display: hdmi: get RGB quant from REG programmed by BL.
[ 6.339240] tegradc 15200000.display: hdmi: get YCC quant from REG programmed by BL.
[ 6.340003] extcon-disp-state external-connection:disp-state: cable 48 state 1
[ 6.340202] Extcon AUX2(HDMI) enable
[ 6.340606] tegradc 15220000.display: disp1 connected to head2->sor1
[ 6.340812] tegradc 15220000.display: parse_dp_settings: No dp-lt-settings node
[ 6.341124] tegradc 15220000.display: DT parsed successfully
[ 6.341288] tegradc 15220000.display: dc.2 probe not in device tree order, deferring
[ 6.353660] tegra194-pcie 141a0000.pcie: Link up
[ 6.354966] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 6.355150] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 6.356855] pci_bus 0005:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x3a100000-0x3a1fffff])
[ 6.367018] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 6.374799] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 6.385443] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 6.391165] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 6.403873] pci 0005:01:00.0: [1d6a:00b1] type 00 class 0x020000
[ 6.404170] pci 0005:01:00.0: reg 0x10: [mem 0x00000000-0x0000ffff 64bit]
[ 6.410067] pci 0005:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 6.417051] pci 0005:01:00.0: reg 0x20: [mem 0x00000000-0x003fffff 64bit]
[ 6.423407] pci 0005:01:00.0: reg 0x30: [mem 0x00000000-0x0003ffff pref]
[ 6.430486] pci 0005:01:00.0: enabling Extended Tags
[ 6.435799] pci 0005:01:00.0: supports D1 D2
[ 6.439807] pci 0005:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 6.452718] pci 0005:00:00.0: BAR 14: assigned [mem 0x1f40000000-0x1f405fffff]
[ 6.453372] pci 0005:01:00.0: BAR 4: assigned [mem 0x1f40000000-0x1f403fffff 64bit]
[ 6.461592] pci 0005:01:00.0: BAR 6: assigned [mem 0x1f40400000-0x1f4043ffff pref]
[ 6.468696] pci 0005:01:00.0: BAR 0: assigned [mem 0x1f40440000-0x1f4044ffff 64bit]
��WARNING: clock_disable: clk_power_ungate on gated domain 27 for gpcclk
��[ 6.476908] pci 0005:01:00.0: BAR 2: assigned [mem 0x1f40450000-0x1f40450fff 64bit]
[ 6.476914] tegradc 15200000.display: blank - powerdown
[ 6.476971] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 6.476978] pci 0005:00:00.0: bridge window [mem 0x1f40000000-0x1f405fffff]
[ 6.476994] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 6.477035] pci 0005:01:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 6.477502] pcieport 0005:00:00.0: Adding to iommu group 10
[ 6.477902] pcieport 0005:00:00.0: PME: Signaling with IRQ 30
[ 6.478156] pcieport 0005:00:00.0: AER: enabled with IRQ 30
[ 6.479795] tegradc 15210000.display: disp1 connected to head1->sor
[ 6.479818] tegradc 15210000.display: parse_dp_settings: No dp-lt-settings node
[ 6.479926] tegradc 15210000.display: DT parsed successfully
[ 6.479970] tegradc 15210000.display: Display dc.000000003b385655 registered with id=1
[ 6.480074] tegradc 15210000.display: vblank syncpt # 13 for dc 1
[ 6.480079] tegradc 15210000.display: vpulse3 syncpt # 14 for dc 1
[ 6.486358] tegradc 15210000.display: probed
[ 6.506032] nvethernet 2490000.ethernet: Adding to iommu group 30
[ 6.506214] nvethernet 2490000.ethernet: failed to read skip mac reset flag, default 0
[ 6.506219] nvethernet 2490000.ethernet: failed to read MDIO address
[ 6.506225] nvethernet 2490000.ethernet: setting to default DMA bit mask
[ 6.506229] nvethernet 2490000.ethernet: set default TXQ to TC mapping
[ 6.506233] nvethernet 2490000.ethernet: Setting default PTP RX queue
[ 6.506242] nvethernet 2490000.ethernet: Failed to read DMA Tx ring size, using default [1024]
[ 6.506246] nvethernet 2490000.ethernet: Failed to read DMA Tx ring size, using default [1024]
[ 6.513721] nvethernet 2490000.ethernet: failed to get eqos_rx_m clk
[ 6.513730] nvethernet 2490000.ethernet: failed to get eqos_rx_input clk
[ 6.513734] nvethernet 2490000.ethernet: failed to get eqos_tx_divider clk
[ 6.514887] nvethernet 2490000.ethernet: Ethernet MAC address: 48:b0:2d:18:49:75
[ 6.514931] nvethernet 2490000.ethernet: Macsec not supported
[ 6.516007] nvethernet 2490000.ethernet: eth0 (HW ver: 50) created with 1 DMA channels
[ 6.516711] irq: IRQ287: trimming hierarchy from :pmc@c360000
[ 6.516823] irq: IRQ288: trimming hierarchy from :interrupt-controller@3881000
[ 6.516917] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 6.517591] tegra-se-nvhost 15810000.se: Adding to iommu group 31
[ 6.519049] tegra-se-nvhost 15810000.se: initialized
[ 6.520497] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 6.520965] tegra-se-nvhost 15820000.se: Adding to iommu group 32
[ 6.521391] extcon-disp-state external-connection:disp-state: cable 48 state 0
[ 6.521398] Extcon AUX2(HDMI) disable
[ 6.521647] tegra-se-nvhost 15820000.se: initialized
[ 6.523154] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 6.523550] tegra-se-nvhost 15830000.se: Adding to iommu group 33
[ 6.524199] tegra-se-nvhost 15830000.se: initialized
[ 6.525155] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 6.525642] tegra-se-nvhost 15840000.se: Adding to iommu group 34
[ 6.526277] tegra-se-nvhost 15840000.se: initialized
[ 6.527719] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 6.528799] tegra_actmon d230000.actmon: in actmon_register()...
[ 6.528959] tegra_actmon d230000.actmon: bwmgr_disable = 0
[ 6.529441] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 6.529940] hvc_sysfs: hypervisor is not present
[ 6.579804] ALSA device list:
[ 6.579810] No soundcards found.
[ 6.586733] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 6.587544] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 6.593664] tegra_cec 3960000.tegra_cec: Can't find physical address.
[ 6.593668] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 6.598357] tegradc 15200000.display: unblank
[ 6.599531] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 6.599728] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 6.609166] tegradc 15200000.display: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 6.610956] tegradc 15200000.display: hdmi: get YCC quant from EDID.
[ 6.615099] extcon-disp-state external-connection:disp-state: cable 48 state 1
[ 6.615102] Extcon AUX2(HDMI) enable
[ 6.627725] tegradc 15200000.display: sync windows ret = 247
[ 6.941526] tegradc 15210000.display: fb registered
[ 6.944880] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 6.946795] tegradc 15220000.display: disp2 connected to head2->sor1
[ 6.953528] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 6.960212] tegradc 15220000.display: parse_dp_settings: No dp-lt-settings node
[ 6.960273] tegradc 15220000.display: DT parsed successfully
[ 6.967777] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 6.975103] tegradc 15220000.display: Display dc.00000000fcf18ce8 registered with id=2
[ 6.994309] tegradc 15210000.display: blank - powerdown
[ 6.994331] extcon-disp-state external-connection:disp-state: cable 53 state 1
[ 6.999805] tegradc 15220000.display: vblank syncpt # 19 for dc 2
[ 7.006661] Extcon HDMI: HPD enabled
[ 7.006672] tegradc 15200000.display: hdmi: plugged
[ 7.006693] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 7.006697] Extcon DP: HPD disabled
[ 7.006700] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 7.006708] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 7.006727] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 7.012791] tegradc 15220000.display: vpulse3 syncpt # 20 for dc 2
[ 7.065468] tegradc 15220000.display: probed
[ 7.066683] tegradc 15220000.display: fb registered
[ 7.071923] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 7.075880] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 7.077057] Freeing unused kernel memory: 3968K
[ 7.083496] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 7.093664] tegradc 15220000.display: blank - powerdown
[ 7.098896] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 7.105803] Run /init as init process
[ 7.107206] Extcon DP: HPD disabled
[ 7.114457] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 7.114466] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 7.127060] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 7.181842] Root device found: mmcblk0p1
[ 7.184724] Found dev node: /dev/mmcblk0p1
[ 7.222711] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 7.227230] Rootfs mounted over mmcblk0p1
[ 7.254758] Switching from initrd to actual rootfs
[ 7.371316] systemd[1]: System time before build time, advancing clock.
[ 7.423558] systemd[1]: systemd 245.4-4ubuntu3.19 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +)[ 7.428056] systemd[1]: Detected architecture arm64.
[ 7.471526] systemd[1]: Set hostname to <hc-ai-wn-0n>.
[ 7.864201] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 7.865729] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 7.870403] systemd[1]: Created slice system-getty.slice.
[ 7.874243] systemd[1]: Created slice system-modprobe.slice.
[ 7.877909] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 7.881844] systemd[1]: Created slice User and Session Slice.
[ 7.884791] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 7.887785] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 7.891376] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 7.894488] systemd[1]: Reached target Local Encrypted Volumes.
[ 7.898670] systemd[1]: Reached target Paths.
[ 7.901367] systemd[1]: Reached target Remote File Systems.
[ 7.905434] systemd[1]: Reached target Slices.
[ 7.908176] systemd[1]: Reached target Swap.
[ 7.911421] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 7.914442] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 7.918222] systemd[1]: Listening on Journal Audit Socket.
[ 7.921468] systemd[1]: Listening on Journal Socket (/dev/log).
[ 7.924792] systemd[1]: Listening on Journal Socket.
[ 7.928174] systemd[1]: Listening on Network Service Netlink Socket.
[ 7.931394] systemd[1]: Listening on udev Control Socket.
[ 7.934441] systemd[1]: Listening on udev Kernel Socket.
[ 7.941336] systemd[1]: Mounting Huge Pages File System...
[ 7.948329] systemd[1]: Mounting POSIX Message Queue File System...
[ 7.955378] systemd[1]: Mounting Kernel Debug File System...
[ 7.962549] systemd[1]: Mounting Kernel Trace File System...
[ 7.971126] systemd[1]: Starting Journal Service...
[ 7.978928] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 7.985862] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[ 7.988905] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 7.994226] systemd[1]: Starting Load Kernel Module efi_pstore...
[ 8.000815] systemd[1]: Starting Load Kernel Module pstore_blk...
[ 8.007527] systemd[1]: Starting Load Kernel Module pstore_zone...
[ 8.014088] systemd[1]: Starting Load Kernel Module ramoops...
[ 8.016891] systemd[1]: Condition check resulted in OpenVSwitch configuration for cleanup being skipped.
[ 8.021978] systemd[1]: Starting NVIDIA specific first-boot udev script...
[ 8.026217] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 8.027858] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 8.036281] systemd[1]: Starting Load Kernel Modules...
[ 8.042567] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 8.048951] systemd[1]: Starting udev Coldplug all Devices...
[ 8.057733] systemd[1]: Mounted Huge Pages File System.
[ 8.060994] systemd[1]: Mounted POSIX Message Queue File System.
[ 8.064181] systemd[1]: Mounted Kernel Debug File System.
[ 8.068561] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 8.068854] systemd[1]: Mounted Kernel Trace File System.
[ 8.074060] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 8.077260] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 8.077940] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x00000000ce000000,704643072
[ 8.095027] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 8.095040] nvmap_page_pool_init: Total RAM pages: 7936712
[ 8.095043] nvmap_page_pool_init: nvmap page pool size: 992089 pages (3875 MB)
[ 8.095339] nvmap_background_zero_thread: PP zeroing thread starting.
[ 8.103315] misc nvmap: created heap vpr base 0x00000000ce000000 size (688128KiB)
[ 8.129818] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 8.129831] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 8.146997] systemd[1]: modprobe@chromeos_pstore.service: Succeeded.
[ 8.153358] systemd[1]: Finished Load Kernel Module chromeos_pstore.
[ 8.160805] systemd[1]: modprobe@efi_pstore.service: Succeeded.
[ 8.166186] systemd[1]: Finished Load Kernel Module efi_pstore.
[ 8.172821] systemd[1]: modprobe@pstore_blk.service: Succeeded.
[ 8.178214] systemd[1]: Finished Load Kernel Module pstore_blk.
[ 8.184996] systemd[1]: modprobe@pstore_zone.service: Succeeded.
[ 8.190167] systemd[1]: Finished Load Kernel Module pstore_zone.
[ 8.197690] systemd[1]: modprobe@ramoops.service: Succeeded.
[ 8.201645] systemd[1]: Finished Load Kernel Module ramoops.
[ 8.207656] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 8.207656]
[ 8.209176] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 8.240135] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 8.241789] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 8.247351] systemd[1]: Starting Load/Save Random Seed...
[ 8.254481] systemd[1]: Starting Create System Users...
[ 8.270330] systemd[1]: Finished Load Kernel Modules.
[ 8.274304] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[ 8.279775] systemd[1]: Mounting Kernel Configuration File System...
[ 8.286847] systemd[1]: Started OP-TEE Client Supplicant.
[ 8.293836] systemd[1]: Starting Apply Kernel Variables...
[ 8.301044] systemd[1]: nvfb-udev.service: Succeeded.
[ 8.304531] systemd[1]: Finished NVIDIA specific first-boot udev script.
[ 8.310291] systemd[1]: Finished Load/Save Random Seed.
[ 8.313665] systemd[1]: Mounted Kernel Configuration File System.
[ 9.881038] using random self ethernet address
[ 9.882172] using random host ethernet address
[ 10.343782] using random self ethernet address
[ 10.344801] using random host ethernet address
Ubuntu 20.04.5 LTS hc-ai-wn-0n ttyTCU0
hc-ai-wn-0n login: adminxxxx (automatic login)
Welcome to Ubuntu 20.04.5 LTS (GNU/Linux 5.10.104-tegra aarch64)
* Documentation: https://help.ubuntu.com
* Management: https://landscape.canonical.com
* Support: https://ubuntu.com/advantage
This system has been minimized by removing packages and content that are
not required on a system that users do not log into.
To restore this content, you can run the 'unminimize' command.
The programs included with the Ubuntu system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Ubuntu comes with ABSOLUTELY NO WARRANTY, to the extent permitted by
applicable law.
To run a command as administrator (user "root"), use "sudo <command>".
See "man sudo_root" for details.
