How to verify CloudXR server work normally?
I am using CloudXR to stream Isaac Sim contents to my Quest 3 headset. I have installed CloudXR server and SteamVR in my PC and load the client APK to Quest 3. I can’t get the Isaac Sim stream work. How can I verify that my CloudXR server is working without problem? and how to make sure my CloudXR client APK is work?
I would suggest you start with the new debugging guide It’s a tutorial that should get you from setting up a server to streaming over a network:
Isaac Sim streaming may be a bit more complicated, and you’ll need to ask in the Isaac Sim forums about how to correctly configure it for VR. I will say that there might or might not be a CloudXR plugin inside of Isaac Sim, which significantly complicates things. A more reliable way to start is to use SteamVR with your Omniverse / Isaac Sim application, and use CloudXR with SteamVR.
