Hello M.Kadlof,
What version of DGX OS and NVSM are you using?
In DGX OS 5.1 / NVSM 21.07.x, we have a command to raise a test alert and clear it.
Generating Test Alert for Email
From within an NVSM CLI interactive session, a user may generate a test alert in order to trigger an SMTP instance and receive an email notification.
Create Testalert
NVSM CLI provides a “create testalert” command to generate a dummy alert that will trigger any SMTP or Call Home defined notification
~$ sudo nvsm create testalert
Within an NVSM CLI interactive session, this basic command will generate a dummy alert with default component_id = Test0 and severity = Warning
In order to configure the Severity and Component of a test alert, the NVSM CLI also provides the following advanced command,
~$ sudo nvsm create testalert <component_id>
which allows for alert specificity to match the severity criteria for a notification. For example,
~$ sudo nvsm create testalert Email1 Critical
will generate a dummy alert with component_id = Email1 and severity = Critical
Clear Testalert
NVSM CLI also provides a “clear testalert” command to dismiss a generated dummy alert
~$ sudo nvsm clear testalert
Within an NVSM CLI interactive session, this basic command will clear any test alert with component_id=Test0, even if there are multiple.
To specify which test alert to dismiss, the NVSM CLI also provides the following command,
~$ sudo nvsm clear testalert <component_id>
Show Testalert
To display all generated test alerts, the NVSM CLI provides a “show testalerts” command
~$ sudo nvsm show testalerts
After running “create testalert”, the following output is expected from “show testalerts”
/systems/localhost/testalerts/alert0
Properties:
system_name = system-name5
message_details = Dummy Test
description = No component is reporting an error. This is a test.
event_time = 2021-08-04T15:55:46.926710484-07:00
recommended_action = Please run ‘sudo nvsm clear testalert’ to dismiss this alert.
alert_id = NV-TEST-01
system_serial = To be filled by O.E.M.
message = Test Alert.
severity = Warning
clear_time = -
hidden = false
type = TestAlerts
It will take less than a minute to generate an alert after an event has occurred.
-Mahendra Yekkar
NVSM Team
