How to view variables in nSight/CUDA runtime?
For C++/CUDA, I am trying to debug a kernel, but I cannot see some of the local variables. I added some code to the sample addKernel to illustrate:
struct Test
	unsigned long long iLL, jLL, kLL;
	int i, j, k;
	double piLL;
__global__ void addKernel(int *c, const int *a, const int *b)
    int i = threadIdx.x;
	int j = 12345;
	float f = 1234.5;
	double pi = 3.1415926535;
	bool b0 = false, b1 = true;
	char ch = 123;
	char s[10] = "A string.";
	Test t;
	t.i = 100; t.j = 200; t.k = 12345678;
	t.iLL = 0xfedcba9876543210; t.jLL = 0x1111222233334444; t.kLL = ~0ULL;
	t.piLL = 3.14159265358979323846;
    c[i] = a[i] + b[i];
When I stop at a breakpoint, set at the last line (“20. c[i]…”), the Locals window shows
@flatBlockIdx	0	long
@flatThreadIdx	0	long
+threadIdx	{x = 0, y = 0, z = 0}	const uint3
+blockIdx	{x = 0, y = 0, z = 0}	const uint3
+blockDim	{x = 5, y = 1, z = 1}	const dim3
+gridDim	{x = 1, y = 1, z = 1}	const dim3
@gridId	1	const long long
-s	0x0000000000fffc10  {0 '	char[10] __local__
	[0]	0 '	__local__ char&
	[1]	0 '	__local__ char&
	[2]	0 '	__local__ char&
	[3]	0 '	__local__ char&
	[4]	0 '	__local__ char&
	[5]	0 '	__local__ char&
	[6]	0 '	__local__ char&
	[7]	0 '	__local__ char&
	[8]	0 '	__local__ char&
	[9]	0 '	__local__ char&
-t	{iLL = 0, jLL = 0, kLL = 0, i = 0, ...}	__local__ Test
	iLL	0	__local__ unsigned long long
	jLL	0	__local__ unsigned long long
	kLL	0	__local__ unsigned long long
	i	0	__local__ int
	j	0	__local__ int
	k	0	__local__ int
	piLL	0	__local__ double
i	0	int
j	12345	int
f	0	float
pi	0	double
b0	false	bool
b1	true	bool
ch	123 '{'	char
+a	0x0000000b02800200  1	__device__ const int* __parameter__
+b	0x0000000b02800400  10	__device__ const int* __parameter__
+c	0x0000000b02800000  0	__device__ int* __parameter__
Notice that neither the values of the array ‘s’, nor the members of the structure ‘t’, are displayed properly. How can I get nSight to show these?
GeForce GTX 1050 Ti, CUDA 9.0 runtime, NSight 5.4, Visual Studio Community 2017 v15.3.4, 64-bit Windows 7
Hi, did you compile your app in debug mode, please make sure that nvcc has “-g”.
Yes, this is a debug build. The nvcc options include both -G and -g. Here is the compiler command line (omitting several libraries):
1>------ Build started: Project: MyProject, Configuration: Debug x64 ------
1>Compiling CUDA source file MyCUDA.cu...
1>
1>C:\MyProject>"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\bin\nvcc.exe" -gencode=arch=compute_30,code=\"sm_30,compute_30\" --use-local-env --cl-version 2017 -ccbin "C:\Program Files (x86)\Microsoft Visual Studio017\Community\VC\Tools\MSVC4.11.25503\bin\HostX86\x64" -x cu  -IC:\MyProject\ -IC:\MyLibraries\Library\Utility -IC:\Miscellaneous_Libraries\Utilities ... -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\include" -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v9.0\include"  -G  --keep --keep-dir x64\Debug -maxrregcount=0  --machine 64 --compile -cudart static -Xptxas -v -g   -DWIN64 -D_WINDOWS -D_DEBUG -DMyBuild -Xcompiler "/EHsc /W3 /nologo /Od /FS /Zi /RTC1 /MTd " -o x64\Debug\MyCUDA.cu.obj "C:\MyProject\MyCUDA.cu"
The bug has been submitted, looks like that nsight cannot handle the array and struct var very well.
