I am able to run TensorRT sample code given in example directory, uff_mnist.py. I have saved my optimized engine using trt.utils.write_engine_to_file() . I used Tensorflow protobuf (.pb) model file to generated optimized TensorRT engine. I am getting accurate result and 100 time less time using TensorRT. Now I want to see this optimized graph in Tensorboard. Need help for this, I searched but did not get any reference regarding this. So please help me how we can visualize the graph using optimized_model.engine and Tensorboard/any_other_library? Thanks in Advance.
For generating the Tensorboard, I used to use the tf.import_graph_def to import the optimized graph_def into a tf.Graph, then create a session with the tf.graph, and output tensorboard with tf.summary.FileWriter.
I didn’t see the uff_mnist.py file in our latest tensorrt container. Please let me know where you find it. It’d be good if I can look into the code.
If i understand it right, using the method you described above is for the not optimized TensorFlow graph.
The question is how it possible to visualize the TensorRT optimized graph after it generated by the uff parser as a CUDA engine using the following C++ APIs:
nvuffparser::IUffParser::m_parser,
nvinfer1::IBuilder::buildCudaEngine
No. Currently, Tensorrt APIs do not support getting a Tensorflow graph from a plan file.
However, as per the documentation, it’s recommended to use the integration as a method for
converting your TensorFlow network. In this case, you will get a graph.
Steps:
Use the trt.create_inference_graph() method, which returns an optimized graph.
Then generate the tensorboard with the optimized graph as described above.
I understand that for now there is no option to visualize the plan file that was generated by the nvinfer1::IBuilder::buildCudaEngine.
These are my questions:
Is there a roadmap to support it in future release?
How much the plan file and the generated graph (model), that was generated by the trt.create_inference_graph service, are close?
Can I use the generated graph from the trt.create_inference_graph service by the TensorRT C++ APIs? How?
My purpose is to have the ability to debug the model\plan\graph that was generated by the TensorRT.
I’m working with the TensorRT C++ and not with the TensorRT Python and using the Jetson Xavier for inference it.
I’m also have the ability to inference the original Tensorflow model using the Tensorflow c++ APIs without any involvement of the TensorRT.
The Tensorflow C++ inference working well while the TensorRT C++ isn’t.
I only have the Tensorflow forzen graph without any access to its source code.
