Operating System:
Windows
Kit Version:
107 (Kit App Template)
Kit Template:
USD Composer
GPU Hardware:
40 series
GPU Driver:
Other
Work Flow:
I designed a cantilever beam in Siemens NX and performed structural analysis in Simcenter. I exported the results as a JT file. I then converted the JT file to a USDZ file (the attached image shows the current result of this conversion). I would like to visualize the structural analysis results, including the contour plot, in NVIDIA USD Composer.
Main Issue:
Is it possible to convert a JT file (exported from Siemens NX/Simcenter) to a USD or USDZ file and display the structural analysis results, such as contour plots, in NVIDIA USD Composer? If so, what is the recommended workflow or which tools should I use to achieve this?
According to this link, it seems that SimScale can output contour data by importing analysis data into Omniverse and converting it to USD format. However, I am wondering whether Siemens NX or Simcenter have similar converters available. Or would we need to develop such a converter ourselves?
https://docs.omniverse.nvidia.com/extensions/latest/ext_simscale.html#fea-import-options
Thank you for your detailed explanation.
I was able to output the colored mesh using the JT Converter, since the JT file was encoded with displayable meshes.
However, I am not sure I fully understand the part:
“but it will not interpret raw result fields (like stress/strain arrays) natively as contour plots in USD.”
Does this mean that the stress or strain values from the analysis are converted only into color information, and that USD Composer cannot directly visualize the raw numerical data (such as stress or strain values) as contour plots?
If possible, could you provide an example or further explanation?
Thank you for your support.
