How to write CAN filter parameters in Rig file?
I’m writing can filter parameters into Rig file.
I have seen the CAN Bus Message Logger Sample.
./sample_canbus_logger --driver=[can.virtual|can.socket|can.aurix]
                       --params=[comma/separated/key/value/pairs]
                       --filter=[id1:mask1,id2:mask2,..]
                       --send_i_understand_implications=[timeout]
                       --send_id=[message_ID]
But it didn’t work in rig file. I wrote like this.
"parameter": "device=can0,file-buffer-size=8192",
"filter":"102:FFF"
"properties": null,
"protocol": "can.socket"
And I couldn’d find the format for CAN filter in “Rig File Format” Page.
What’s the correct format for CAN filter?
Dear Matsu_Cho,
If the Rig File Format you mentioned is EasyCanConfigFile.conf, the file is in <PDK_install_dir>/drive-t186ref-linux/samples/easycan on your hostPC. Thanks.
Thanks for your replying.
But I’m sorry I meant the .json file, not .conf file.
The .json file format I referred is this link.
\NVIDIA_DRIVE_SW_9.0_References\DRIVE_Software\DRIVE AV\baggage\rigconfiguration_usecase0.html
Dear Matsu_Cho,
Unfortunately there is no rig support for it, the filter has to be set through the special dwSensorCAN_setMessageFilter function as shown in the sample : /usr/local/driveworks-2.0/samples/src/sensors/canbus/logger
Could you please refer to the sample for this topic? Thanks.
