sdkmanager 1.8.10363
using a customized board (avermedia nx211b) i need to stay with jetpack 4.6.x and not use jetpack 5.x. furthermore i do not want to flash my board, because that led to incompatibilities with my sd-card (reader).
how do in force sdkmanager to install 4.6 instead of 5.x? i did not find any way to select an older version.
do i have to download a different version of the sdkmanager…deb?
What do you see on your sdkmanager?
Hi Benutzer2975,
Please run below command to install old version JetPack:
$ sdkmanager --archivedversions
solved. the problem was due to the version of ubuntu.
(thought, --archivedversions (1) would do the trick, but it didn’t)
- ubuntu-20 only has 5.0 as a choice
- ubuntu-18 has 4.6 (and others via (1) as a choice
thanks to all repliers for your help
