HP OMEN 16-am0015ns: brightness control non-functional
HP OMEN 16-am0015ns — BACKLIGHT / BRIGHTNESS CONTROL NOT WORKING UNDER LINUX
Diagnostic report & tested procedures
SYSTEM
Laptop : HP Omen 16-am0015ns
CPU / iGPU : Intel Core Ultra 7 255H (Arrow Lake, Xe iGPU)
dGPU : NVIDIA GeForce RTX 5060 Mobile (proprietary driver 595.x)
RAM : 32 GB
OS : Fedora Linux 44 KDE Plasma (Wayland)
Kernel : 7.0.13-200.fc44.x86_64
BIOS : F.14 (latest available)
Display server: Wayland (KDE Plasma 6)
SYMPTOM
  • Screen brightness is stuck at a fixed level.
  • KDE brightness slider has NO effect on the physical backlight.
  • Brightness Fn keys: with the default config, no working slider; with
    acpi_backlight=video the slider/keys respond in the UI but the physical
    brightness still does NOT change.
  • Writing values directly to the sysfs backlight interface is accepted by
    the kernel (value is stored) but does NOT change the physical brightness.
DIAGNOSTIC PROCEDURE (step by step, reproducible)
STEP 1 — Identify registered backlight interfaces
$ ls -la /sys/class/backlight/
intel_backlight → …pci0000:00/0000:00:02.0/drm/card1/card1-eDP-1/intel_backlight
$ cat /sys/class/backlight/intel_backlight/type => raw
$ cat /sys/class/backlight/intel_backlight/max_brightness => 38400
$ cat /sys/class/backlight/intel_backlight/actual_brightness => 23040
Only ONE interface exists by default: intel_backlight (raw, Intel iGPU side).
STEP 2 — Test direct write (bypass KDE and Fn keys)
$ echo 10000 | sudo tee /sys/class/backlight/intel_backlight/brightness
$ echo 30000 | sudo tee /sys/class/backlight/intel_backlight/brightness
RESULT: value is accepted, but the physical screen brightness does NOT change.
=> The interface exists but is disconnected from the actual panel PWM/control.
STEP 3 — Inspect kernel boot messages for video/backlight
$ sudo dmesg | grep -iE “backlight|brightness|acpi.*video”
ACPI: video: Video Device [PXSX] (multi-head: no rom: yes post: no)
ACPI: video: Video Device [GFX0] (multi-head: yes rom: no post: no)
TWO ACPI video devices are registered:
  • PXSX => PCIe subtree (NVIDIA side)
  • GFX0 => Intel iGPU side
STEP 4 — Map DRM cards, drivers and eDP panels
$ readlink -f /sys/class/drm/card0/device/driver => nvidia
$ readlink -f /sys/class/drm/card1/device/driver => i915
eDP panels found:
card0-eDP-2 → pci 0000:01:00.0 (NVIDIA RTX 5060)
card1-eDP-1 → pci 0000:00:02.0 (Intel iGPU)
KEY FINDING: there are TWO eDP endpoints, one on each GPU.
The only backlight interface (intel_backlight) lives on the Intel eDP,
but the physical panel appears to be routed/controlled through the NVIDIA side.
STEP 5 — Check NVIDIA WMI EC backlight path
$ modinfo nvidia_wmi_ec_backlight
=> module EXISTS (description: NVIDIA WMI EC Backlight driver)
$ ls /sys/class/wmi/ => empty
$ ls /sys/bus/wmi/devices/ => 21 WMI GUIDs listed, but NONE is
603E9613-EF25-4338-A3D0-C46177516DB7
(the GUID required by nvidia_wmi_ec_backlight)
$ sudo modprobe nvidia_wmi_ec_backlight
=> loads with exit 0 but creates NO interface (GUID absent from firmware)
Additional firmware errors in dmesg:
ACPI Error: Aborting method _SB.WMID.WQBZ … (AE_AML_BUFFER_LIMIT)
ACPI Error: Aborting method _SB.WMID.WQBE … (AE_AML_BUFFER_LIMIT)
=> The NVIDIA WMI EC backlight method cannot bind: HP firmware does not
expose the required WMI GUID, and some WMI methods fail with buffer errors.
STEP 6 — Inspect ACPI tables (DSDT + 24 SSDTs)
$ sudo cp /sys/firmware/acpi/tables/{DSDT,SSDT*} . (extract all tables)
$ iasl -d SSDT14.dat (decompile)
Brightness methods _BCL / _BCM / _BQC are present under:
Scope (_SB.PC00.GFX0) ← Intel graphics node
Device (DD1F) { _BCL, _BCM, _BQC }
Device (DD2F) { _BCL, _BCM, _BQC }
=> The ACPI brightness methods DO exist under the Intel GFX0 node in SSDT14,
yet they produce no physical effect (panel control is on the NVIDIA side).
TESTED KERNEL PARAMETERS (acpi_backlight) — ALL VIA grubby, PERSISTENT
Applied with:
sudo grubby --update-kernel=ALL --args=“acpi_backlight=VALUE”
Removed with:
sudo grubby --update-kernel=ALL --remove-args=“acpi_backlight=VALUE”
| Parameter | Interfaces after reboot | Physical effect|
| (default, none) | intel_backlight | NONE |
| acpi_backlight=native | intel_backlight | NONE |
| acpi_backlight=vendor | (none - list empty) | NONE (worse) |
| acpi_backlight=video | acpi_video0, acpi_video1 | NONE* |
  • with acpi_backlight=video the KDE slider and Fn keys DO respond and the
    values update (scale 0-100), but the physical brightness still does NOT
    change on any of the interfaces.
CONCLUSION (so far)
  • None of the standard Linux backlight mechanisms (Intel native PWM,
    acpi_video) actually control the physical panel backlight.
  • The panel is routed/controlled through the NVIDIA dGPU side.
  • The NVIDIA WMI EC backlight driver cannot bind because HP firmware does
    not expose the required WMI GUID (603E9613-EF25-4338-A3D0-C46177516DB7).
  • Moving the ACPI _BCL/_BCM/_BQC methods via a DSDT override is unlikely to
    help, because the problem is the physical control path (panel on NVIDIA),
    not the location of the methods in the ACPI tree.
ADDITIONAL PARAMETERS TESTED (all applied and reverted, none worked)
A) Intel eDP AUX/DPCD backlight (acts on intel_backlight, iGPU side):
sudo grubby --update-kernel=ALL --args=“i915.enable_dpcd_backlight=1”
Rationale: some eDP panels control backlight over the AUX channel (DPCD
registers) instead of PWM; i915 defaults to PWM which may not work.
RESULT: no change. Still only intel_backlight (type stays “raw”), no
physical effect. DISCARDED.
B) NVIDIA backlight handler (acts on NVIDIA side):
nvidia.NVreg_RegistryDwords=EnableBrightnessControl=1
Note: NVreg_EnableBacklightHandler is NOT available in this driver
(595.80 Open) - confirmed absent via modinfo nvidia. NVIDIA removed it.
Only the RegistryDwords=EnableBrightnessControl key could be tested.
RESULT: parameter confirmed active in /proc/cmdline, but no NVIDIA
backlight interface was created (no nvidia_0), physical brightness
unchanged. DISCARDED.
DRIVER ALTERNATIVE RULED OUT:
The RTX 5060 is Blackwell architecture. Per NVIDIA documentation, Blackwell
GPUs are supported ONLY by the open-source kernel modules; the legacy
proprietary (closed) kernel module is not available for this GPU. Therefore
switching to the “proprietary” driver branch to change backlight behaviour
is NOT possible - the 595.80 Open module is the only official NVIDIA driver
for this card.
FINAL CONCLUSION
Every standard Linux backlight mechanism has been tested and none controls
the physical panel:
  • acpi_backlight = native / vendor / video
  • i915.enable_dpcd_backlight=1
  • nvidia.NVreg_RegistryDwords=EnableBrightnessControl=1
    No alternative NVIDIA driver branch exists for Blackwell to try.
Root cause is upstream, not local configuration:
  • The physical panel is routed/controlled through the NVIDIA side.
  • HP firmware does not expose the WMI GUID required by
    nvidia_wmi_ec_backlight (603E9613-EF25-4338-A3D0-C46177516DB7).
  • Some HP WMI methods fail with AE_AML_BUFFER_LIMIT.
    Resolution will require either an HP firmware update exposing the WMI GUID,
    or improved Arrow Lake / Blackwell backlight support in a future kernel /
    NVIDIA driver release.
REFERENCE BUG REPORTS
  • kernel.org Bugzilla (ACPI component): #221530, #221648
  • NVIDIA open-gpu-kernel-modules GitHub: #1202
  • HP community forum thread (this report)
NOTE: Secure Boot is disabled. NVIDIA proprietary driver in use.
nouveau/nova_core blacklisted. Kernel cmdline includes
nvidia-drm.modeset=1 nvidia-drm.fbdev=1.
