HP Reverb G2 clamped to 6 bpc because its EDID leaves color depth undefined — root cause found + two-line patch, but 90 Hz still fails to light
Summary
Two findings on the HP Reverb G2 (EDID ManufID 0x220E) with the 595.71.05 open kernel
modules. They are independent, and the first one is not specific to this headset:
  1. A confirmed bug with a one-line fix. nvkms-dpy.c treats “the EDID did not declare a
    color depth” as “the sink wants 6 bpc” and drives the DisplayPort link at 18 bpp. The DSI
    branch of the same function already treats that same input as 8 bpc. This applies to
    any DisplayPort sink that leaves EDID Color Bit Depth undefined — on an ordinary
    monitor it would show up as banding, easy to misattribute to the panel. Confirmed in
    dmesg, and independently by the sink itself reporting the bpc back to the host. The
    condition is unchanged on main as of 610.57.04 (nvkms-dpy.c:3468).
  2. A failure that the patch does not fix. Both of this headset’s 90 Hz modes still fail
    to display correctly while its 60 Hz mode works. I have ruled out link bandwidth, DSC,
    color space, mode derivation, the display path, and the sink’s own reported panel state —
    what is left appears to sit below the open kernel modules.
Everything about the 90 Hz behaviour below was verified by physically looking inside the
headset, because the API layer reports a successful modeset and a happy 90.0 fps with the
panel dark. It failed on every attempt, nine runs, across two display paths that share
almost no driver code.
I believe this is the same underlying problem as the “60 Hz only on Reverb G2” reports
tracked as bug 5923212 — please correct me if I’m conflating two different bugs.
Environment
  • GPU: RTX 3060 Ti (GA104, Ampere)
  • Driver: 595.71.05, open kernel modules (nvidia-kernel-open-dkms)
  • OS: Debian 13 (trixie), kernel 6.12.100+deb13-amd64
  • Tested on both X11 NVIDIA Direct-Mode and Wayland (GNOME 48.7 / mutter) via DRM lease —
    identical failure on both, so this isn’t specific to one display path.
  • I have only tested 595.71.05 myself; reports of 590.x–610.x being affected come from other
    posters in the earlier thread, not from my own testing.
Symptom
The G2’s EDID advertises three modes: 4320x2160@60 (works), 4320x2160@90 and
2880x1440@90 (both fail). At either 90 Hz mode the panel shows only the static HP boot logo
— no video ever reaches the panel — while Vulkan/DRM report a fully successful modeset and
90.0 fps presented. nvidia-modeset’s own attach log looks identical (success, no errors)
for both the working 60 Hz mode and the failing 90 Hz modes.
Finding 1 — the 6 bpc clamp: root cause
The G2’s EDID is 1.4 and leaves the “Color Bit Depth” field of the Video Input Definition
byte (offset 0x14, bits 6-4) at 000 = “undefined” (byte value 0x80).
src/common/modeset/timing/nvt_edid.c:932 parses the undefined case into
input.u.digital.bpc = 0:
default :
    pInfo->input.u.digital.bpc = 0;
    break;
src/nvidia-modeset/src/nvkms-dpy.c:3456, in nvDpyGetOutputColorFormatInfo(), DP branch,
then does:
} else if (pDpyEvo->parsedEdid.info.input.u.digital.bpc < 8) {
    colorFormatsInfo.rgb444.maxBpc = NV_KMS_DPY_ATTRIBUTE_CURRENT_COLOR_BPC_6;
    colorFormatsInfo.yuv444.maxBpc = NV_KMS_DPY_ATTRIBUTE_CURRENT_COLOR_BPC_UNKNOWN;
0 < 8 is true, so an EDID that simply didn’t declare a depth gets clamped to 6 bpc
(18bpp) for every mode, confirmed in dmesg:
nvidia-modeset: DPCONN> Notify Attach Begin (Head 0, pclk 428580000 raster 2980 x 1598  18 bpp)
Note the DSI branch of this same function already treats an unrecognized/unknown bpc as
8, not 6:
default:
    nvAssert(!"Unsupported bpc for DSI");
    // fall through
case 8:
    colorFormatsInfo.rgb444.maxBpc = NV_KMS_DPY_ATTRIBUTE_CURRENT_COLOR_BPC_8;
so DP and DSI disagree on how to handle the exact same “undefined” input, in the same
source file. This is unchanged on main, where the DP condition is at nvkms-dpy.c:3468.
Nothing else in this EDID can override the 0, and that generalizes
Tree-wide (grep -rn 'digital\.bpc[[:space:]]*=' src/), input.u.digital.bpc is written in
three places:
  • nvt_edid.c:914-932 — the base-block switch quoted above.
  • nvt_edidext_displayid20.c:314 — the Display Parameters block of a DisplayID 2.x
    extension.
  • nvkms-dpy.c:2257 — inside CreateParsedEdidFromNVT_TIMING(), reached only from
    GetFixedModeTimings() (nvkms-dpy.c:629) for DSI panels and DP serializers, which
    synthesize a parsed EDID from RM-supplied timings with a caller-provided bpc. It never
    runs for a sink that has a real EDID.
So for a real sink EDID the only override is the DisplayID 2.x one, and which of the two
DisplayID parsers runs is decided in nvt_edid.c:1101 purely by the version byte:
case NVT_EDID_EXTENSION_DISPLAYID:
    if ((pExt[1] & 0xF0) == 0x20) // displayID2.x as EDID extension
        getDisplayId20EDIDExtInfo(...);
    else                          // displayID13 as EDID extension
        getDisplayIdEDIDExtInfo(...);
This headset’s DisplayID extension block starts 70 12 79 00 00 03 ..., i.e. version byte
0x12 = DisplayID 1.2, so 0x12 & 0xF0 == 0x10 and it takes the DisplayID 1.3 path — which
never writes digital.bpc at all. (Its single data block, tag 0x03 / 40 bytes, is two
20-byte Type I Detailed Timing descriptors.)
So this isn’t really a quirk of one headset’s EDID. For any DisplayPort sink whose
DisplayID extension is 1.x — or that has no DisplayID extension — the only override site is
unreachable by construction, so leaving Color Bit Depth undefined in the base block means an
unconditional 6 bpc clamp.
On an ordinary monitor that would show up as banding, which is
easy to misattribute. Here it happens to break a headset.
Independent confirmation via the headset itself
The G2’s companion device reports its own panel state over HID (report 0x05, 33 bytes) —
byte 18 of that report reflects the bpc actually in use. Capturing this on Linux (6 on the
DP-side per above) and on Windows (610.74, same GPU) at the identical mode
(4320x2160@90):
Windows (works):  05 01 01 01 01 5a 00 00 00 09 38 1e 04 00 77 77 00 00 08 44 11 e4 08 ...
Linux (fails):    05 00 01 01 00 5a 00 00 00 09 38 14 04 00 77 77 00 00 06 44 11 e4 08 ...
Byte 18: 06 on Linux vs 08 on Windows, with the same GPU. Windows is driving this sink
at 8 bpc; our open-kernel Linux driver is driving it at 6.
The patch
--- a/src/nvidia-modeset/src/nvkms-dpy.c
+++ b/src/nvidia-modeset/src/nvkms-dpy.c
@@ -3453,7 +3453,8 @@
                         NV_KMS_DPY_ATTRIBUTE_CURRENT_COLOR_BPC_10;
-                } else if (pDpyEvo->parsedEdid.info.input.u.digital.bpc < 8) {
+                } else if (pDpyEvo->parsedEdid.info.input.u.digital.bpc != 0 &&
+                           pDpyEvo->parsedEdid.info.input.u.digital.bpc < 8) {
Treats 0 (“not declared”) the same way the DSI branch already does, and falls through to
the 8bpc default instead of clamping to 6. EDIDs that do declare a depth are unaffected —
they never reach the modified condition with a different result.
Verified effect of the patch
  • dmesg now shows 24 bpp instead of 18 bpp for every mode.
  • The headset’s own status byte 18 goes from 06 to 08, matching Windows exactly.
  • In fact, with the patch applied, the headset’s full 33-byte status report for
    4320x2160@90 becomes byte-for-byte identical to the working Windows capture at the
    same mode.
If you want to reproduce the clamp without building a driver
Attached (g2-edid.zip) is the raw EDID plus a copy with exactly two bytes changed: base
byte 0x14 from 0x80 to 0xA0 (Color Bit Depth undefined → 8 bpc) and the base block
checksum from 0xE8 to 0xC8. Feeding that as an EDID override produces the same 24bpp
result as the source patch. The reverse works on any EDID 1.4 digital sink you can
override: clear bits 6-4 of byte 0x14, fix the checksum at 0x7F, and the attach log
drops to 18 bpp.
Finding 2 — the 90 Hz failure, which this patch does not fix
With the patch applied and 8bpc confirmed on the wire, physical verification (someone
wearing the headset, not API state) at the two 90 Hz modes shows:
  • 4320x2160@90 (905.4 MHz pixel clock): panel lights up and flickers, but shows plain white,
    no color content.
  • 2880x1440@90 (428.6 MHz pixel clock — well under half the bandwidth of the mode above,
    and even under the 60Hz mode’s 709.15 MHz): identical white flicker, no color.
Both 90 Hz modes fail identically despite a >2x difference in pixel clock, which rules out
DP link bandwidth as the differentiator. 4320x2160@60 continues to display correctly with
the same patch applied, so the patch does not regress the working mode.
This is real forward progress — pre-patch, both 90 Hz modes showed nothing but a static
boot logo, no backlight/panel activity at all. Post-patch, the panel activates but doesn’t
render correct pixel content, specifically and only at 90 Hz.
What we ruled out for the remaining 90 Hz failure
  • Color space: ruled out from the EDID itself, not just from logs. The CTA-861 extension
    has byte 3 = 0x00 — this sink advertises no YCbCr 4:4:4 and no YCbCr 4:2:2 at all, so the
    link is necessarily RGB in all three modes and there is no color-space variable that could
    differ between the working mode and the failing ones.
  • DSC: ruled out arithmetically rather than from logs. The mode that works
    (4320x2160@60) is 709.15 MHz x 24 bpp = 17.0 Gbps uncompressed. The failing 2880x1440@90
    is 428.58 MHz x 24 bpp = 10.3 Gbps uncompressed. Whatever link configuration carries
    17.0 Gbps uncompressed carries 10.3 Gbps uncompressed, so DSC cannot be required for
    that mode and therefore cannot explain its failure — and both 90 Hz modes fail identically.
    Consistent with this, there are zero hits for DSC/compression terms in dmesg with
    nvidia_modeset.debug=1 across all three modes.
  • Mode derivation / timings: I decoded all three timings by hand out of the raw EDID and
    compared them against what drmModeGetConnector reports the driver programming:
    source                       pclk       H act/fp/sync/bp    V act/fp/sync/bp     rate
    DisplayID desc #1 (pref)  905.40 MHz  4320 / 50 / 4 / 46  2160 / 16 / 2 /  98  90.00
    DisplayID desc #2         709.15 MHz  4320 / 50 / 4 / 46  2160 / 14 / 2 / 498  60.00
    base block DTD            428.58 MHz  2880 / 50 / 4 / 46  1440 / 18 / 2 / 138  90.00
    All three with positive H and V sync polarity, all three matching what the driver programs
    bit for bit (and matching the raster 2980 x 1598 / pclk 428580000 in the attach log). The
    driver is programming precisely the timings the sink asks for; there is no second root
    cause hiding in mode derivation. Full annotated decode is in the attached zip.
    One structural note, in case it is meaningful to someone who knows the hardware: the
    horizontal blanking is identical across all three modes (50/4/46), and the only thing the
    two failing modes have in common that the working one does not is a much shorter vertical
    blanking interval — 116 and 158 lines, against 514 for the 60 Hz mode. In this sink’s own
    three advertised modes, “90 Hz” and “short vblank” are perfectly confounded.
  • The sink’s own reported panel state: with the patch applied, the headset’s 33-byte
    HID status report at 4320x2160@90 is byte-for-byte identical to the Windows capture at the
    same mode. The companion device believes it is in the same state as during a working
    Windows session, so the difference is not in how the panel was configured out of band.
  • Community open-kernel patches for this headset: in addition to my bpc patch, this
    system has three others applied against 595.71.05 — VESA DisplayID/DSC VSDB
    spec-correctness fixes, DRM-lease enablement for VR HMDs, and a forceMaxLinkConfig WAR
    keyed on EDID ManufID 0x220E in dp_wardatabase.cpp. With all four applied on GA104, both
    90 Hz modes still fail physically. Mentioning it so nobody re-tests that combination:
    nothing found so far at the open kernel module level lights this panel at 90 Hz.
  • NVreg_ResmanDebugLevel: default is already ~0 (all bits); we suspect these debug
    prints are compiled out of release builds, same as nvidia_modeset.debug which is capped
    at 7 fixed lines regardless of value.
  • GSP-RM firmware logs: this GPU (GA104) uses GSP firmware
    (/lib/firmware/nvidia/595.71.05/gsp_ga10x.bin), so a lot of the interesting logic likely
    runs there, not in the open kernel modules. We set NVreg_EnableGpuFirmwareLogs=1
    expecting more detail, but the driver reports it needs gsp_log_ga10x.bin, which is not
    present. We downloaded your official 595.71.05 .run installer in full and confirmed by
    MD5 that its gsp_ga10x.bin is byte-identical to the one already installed — the
    logging-capable firmware variant does not appear to be publicly distributed for this
    consumer GPU. We have no way to see what the GSP does during the 90 Hz negotiation.
Ask
Would appreciate if someone with access to the closed GSP-RM source could look at what
differs at 90 Hz specifically (independent of bandwidth, since both native 90 Hz modes fail
identically) now that the bpc is correctly negotiated. Happy to test additional patches or
provide more diagnostics — I have physical access to the hardware and a working automated
test harness (custom minimal Vulkan display client, bypassing Monado/SteamVR entirely) that
reproduces this on demand.
The bpc part of this is also filed as a pull request against the open kernel modules:
Attached
0004-nvkms-no-6bpc-clamp.patch.txt — the patch above, as git format-patch output against main
g2-edid.zip — raw 384-byte EDID, the 8bpc override copy, and a full annotated decode
nvidia-bug-report.log.gz — captured with the patch applied
Summary: Ran a full 2×2×N factorial isolating refresh rate, vertical blanking, and
pixel clock as independent variables on real hardware (physical verification each time,
headset worn, not just API success). Result: none of resolution, refresh rate, vblank
duration, or total DisplayPort bandwidth alone explain the failure. The only pixel clock
that has ever produced an image, across every combination tried, is exactly ~709.15 MHz
— which is also the bridge chip’s own native 4320x2160@60 timing. That, plus the bridge
chip’s datasheet, points at a hardware/firmware ceiling rather than a pure EDID/mode-timing
problem.
Setup: RTX 3060 Ti, 595.71.05-open, patched with the 3-patch Project-VR stack plus a
4th patch fixing a separate 6bpc-clamp bug in this same EDID (undeclared color depth —
NVIDIA/open-gpu-kernel-modules#1275,
unrelated to this bug but worth ruling out first if anyone else hits it). Modes injected via
nvidia_modeset.config_file EDID override, so htotal/vtotal/refresh are controlled
precisely per attempt. Verified two ways every time: (a) physically, headset worn, backlight
on/off and color vs. logo; (b) the headset’s own HID status report
(DEVICE_STATUS, 33 bytes), which echoes back the negotiated htotal/vtotal/refresh/bpc —
confirms the requested timing actually reached the panel, independent of whether it lit up.
Bridge chip: ANX7530 (Analogix DisplayPort-to-dual-MIPI, VR-targeted), identified from
a firmware version string on the device (ANX7530:x.x). Its product brief
(AA-004263-PB-7) states: “DisplayPort Receiver Input Bandwidth supports up to 4K x 2K x
60Hz” as an explicit spec line, and lists HBR2.5 (6.75 Gbps/lane) as its DisplayPort link
ceiling — not HBR3. Both numbers are far above anything any of our attempted 90Hz modes
needed, so neither the chip’s raw link rate nor total pixel throughput explains the
failures below.
Results (all at 4320x2160 unless noted; vblank time = vblank_lines / ((v_active +
vblank_lines) × refresh)):
label resolution refresh vblank (lines) pixel clock vblank time result
native, working 4320x2160 60.00 Hz 514 709.15 MHz 3.204 ms works
CTRL4K (cloned copy of the working mode, different descriptor slot) 4320x2160 60.00 Hz 514 709.14 MHz 3.204 ms works
A4K 4320x2160 60.00 Hz 116 603.60 MHz 0.849 ms fails
B4K 4320x2160 90.00 Hz 240 954.72 MHz 1.111 ms fails
90long (same vblank line count as the working mode, at 90Hz) 4320x2160 90.00 Hz 514 1063.72 MHz 2.136 ms fails
bisect1 (60Hz, short vblank, no bandwidth pressure) 4320x2160 60.00 Hz 340 663.00 MHz 2.267 ms fails
80hz (more vblank time than the working mode, comfortable bandwidth margin) 4320x2160 80.00 Hz 775 1037.82 MHz 3.301 ms fails
native, previously reported 2880x1440 90.00 Hz — 428.58 MHz — fails (lower total bandwidth than the working mode)
Every row that isn’t ≈709 MHz fails, regardless of whether it has more bandwidth headroom,
more vblank lines, or more vblank time than the one working mode. 80hz is the clearest
single data point: strictly more vertical blanking time than the working 60Hz mode, well
inside the bridge’s own bandwidth spec, and it still doesn’t light up.
What this rules out, with this methodology:
  • Total DisplayPort bandwidth (80hz needs less than the chip’s declared HBR2.5 ceiling
    and still fails; 2880x1440@90, reported earlier in this thread, needs less bandwidth
    than the working mode and also fails).
  • Vertical blanking duration, whether measured in lines or in time (80hz has more than
    the working mode; A4K/bisect1 have less; both buckets fail identically).
  • The EDID/mode-injection mechanism itself not reaching the panel — the headset’s own HID
    status confirms exact timing delivery in every failing case tested.
Open question for anyone with lower-level visibility (DPCD/MSA capture, or the Windows
driver’s internal handling of this panel):
is there a known reason the ANX7530’s PLL (or
its MCU block, per the datasheet’s block diagram) would only lock to specific discrete
pixel clocks rather than an arbitrary continuous range? If so, is ~709 MHz special-cased
somewhere in NVIDIA’s Windows driver for this device (a quirk/allowlist), which the Linux
595-open path doesn’t carry over?
Happy to run more targeted captures if anyone with visibility into the internal bug can
point at what to look for specifically.
Update (2026-08-05, evening): live Windows capture — no special pixel clock, no extra USB
command
With direct access to a Windows machine driving the same headset, I read the active timing
with CRU (Custom Resolution Utility) while 90 Hz was working: 2880x1440 @ 89.999 Hz (428.58 MHz), htotal=2980 vtotal=1598. This is exactly the base-block DTD from the EDID,
unmodified — same pixel clock, same totals. Windows isn’t using any special or out-of-band
timing for this mode: it’s exactly what the EDID itself publishes.
This reframes the open question above (is there a “special” pixel clock cached somewhere in
the Windows driver for this device?): there isn’t, at least not in the sense of a magic value
that differs from the EDID. Windows drives the 60 Hz mode (709.15 MHz, DisplayID descriptor
#2) and the 90 Hz mode (428.58 MHz, base-block DTD) both “as-is,” straight from the EDID.
What separates the two isn’t the pixel clock itself — it’s specifically crossing the
refresh-rate threshold, consistent with the factorial results above.
I also captured, over USB (Wireshark + USBPcap), the exact moment of a live refresh-rate
change on Windows (60→90 Hz and 90→60 Hz, without disconnecting the headset). No additional
HID command appears during the transition — only the usual status report (DEVICE_STATUS,
33 bytes) updating refresh/htotal/vtotal, identical in shape to what’s already seen in steady
state. This rules out a hidden, Windows-specific USB activation sequence as well.
At this point, from the Windows user-tooling side (Wireshark/USBPcap, CRU, HWiNFO64, GPU-Z,
NVIDIA’s own control panel) there’s nothing left to check: no special EDID, no hidden USB
command, no visible DSC (the Reverb G2 doesn’t even show up as a selectable display in the
NVIDIA panel or in Windows Settings while in direct/HMD mode). What’s still invisible from
here is exactly the open question above: what happens during DisplayPort link training
(DPCD/AUX), or inside the closed GSP firmware — no user-space tool reaches either of those on
any OS.
Update: the patch works — 90 Hz now lights up the panel with a real image.
Following up on my original report above (6bpc clamp root-caused, two-line patch, but 90 Hz
still failing to light at the time).
Root cause of that gap, now found: nobody had retested the panel’s native EDID modes with no
EDID override loaded at all, after the patch was in place. The “90 Hz native fails” data
point in my own investigation predates the patch by about 24 hours (it’s from before I’d
found the 6bpc bug), and every subsequent test that ran with the patch active used synthetic,
injected timings to isolate vertical blanking as a variable - never the plain, unmodified
native mode. One of my own working notes even lists the native 2880x1440@90 mode as available
and explicitly skips retesting it, citing the pre-patch result. That’s on me, not a mystery -
just an assumption that outlived the fix that invalidated it.
Retested today with a plain EDID and no override at all: 90 Hz produces a real image,
verified physically with the headset on (flat alternating test colors, and separately with
real decoded video content) - the first time in this whole investigation that anything got
past the boot logo at 90 Hz. Tested at both the supersampled 4320x2160@90 mode and, more
importantly, the native 2880x1440@90 mode (the EDID’s own base-block DTD, unmodified - the
exact mode I separately confirmed via CRU that Windows itself drives this panel with).
One thing still open, and it’s the reason I’m not closing this out yet: the panel still
visually appears to flicker/strobe at what looks like ~60 Hz to the eye, despite genuinely
running at 90 Hz confirmed at every layer I can check - the headset’s own HID status report,
the compositor’s frame pacing (11.111 ms period, matches 90 Hz exactly), and the presentation
API. This persists identically with a synthetic test pattern, with real video content, and at
the native Windows-matching mode too - so it isn’t a rendering/compositor artifact and it
isn’t a “wrong mode” issue either. I don’t have a way to measure the physical backlight
strobe rate directly from here (would need a 120fps+ camera) so I can’t rule in or out yet
whether this is a separate firmware-level backlight-timing behavior, unrelated to the
DisplayPort link itself.
Happy to share the exact steps/config if useful to anyone else hitting this.
For anyone who wants to dig into this directly: the full investigation (patches, test
scripts, EDID tooling, and the dated log of every attempt including the ones that failed)
is public at GitHub - Wintch/reverb-g2: HP Reverb G2 on Linux: NVIDIA driver fixes, Monado patches, and a 360/VR180 player · GitHub. Open to PRs/issues if anyone has a lead on the
backlight-timing question above, or wants to reproduce any of this on their own G2.
EDIT (same day, a few hours later): the flicker question above is resolved — and the
resolution invalidates part of my own evidence, so correcting it here rather than leaving
it standing.
Two of my three “flickers at 90 Hz” observations used my own synthetic test tool, which
alternates its solid fill color every single frame — at 90 fps that is a built-in ~30 Hz
strobe by construction. Those observations were the test flashing, not the panel. I added
a static solid-white mode to the tool and re-ran all three modes, watching the panel
directly:
  • 2880x1440@90 (native, the Windows-matching timing): clean, no flicker
  • 4320x2160@90 (supersampled): clean, no flicker — including when switched to immediately
    after a 60 Hz session, so it isn’t ordering-sensitive either
  • 4320x2160@60: visible flicker — which is exactly what this same headset does on Windows
    at 60 Hz. That makes the 60 Hz flicker the panel’s own backlight behavior at its
    non-native rate, not a Linux or driver issue. Linux and Windows now behave identically
    on this panel: 60 flickers, 90 is clean.
That leaves one earlier observation (real decoded video at 90 Hz, which did appear to
flicker) that I can no longer reproduce. Nothing driver-side changed in between — same
595.71.05-open, same two-line bpc patch, verified active in both states. What did happen
in between: a full reboot and physically re-seating the headset’s USB connection several
times (this unit’s cable has documented marginal contact). The most plausible reading is
a latched panel/backlight state cleared by the power cycling — the headset firmware
manages backlight duty per detected frame timing (the Windows driver’s binaries carry
strings like “left duty %d, right duty %d, frame timing %d”) — but I can’t prove that
without DP AUX access, so it stays labeled a hypothesis.
Bottom line: with the bpc patch, 90 Hz on the G2 with 595-open is fully working and
visually clean at both 90 Hz modes. No remaining flicker complaint against the driver —
the bpc default remains the one real driver issue in this thread.
